[mapserver-users] AGG_Q + raster problem
Brent Fraser bfraser at geoanalytic.com
Tue Feb 19 13:34:01 EST 2008
I'm running out of ideas.  Have you tried setting the output
format to JPG?  Since it's a 24-bit format (only), this
might indicate if the problem is in the output stage or in
the input/processing stage.
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: "'Brent Fraser'" <bfraser at geoanalytic.com>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, February 19, 2008 11:28 AM
Subject: RE: [mapserver-users] AGG_Q + raster problem
Yes, I'm completely sure that the image I've attached was
produced with this
OUTPUT statement:
  OUTPUTFORMAT
    NAME 'AGGA'
    DRIVER AGG/PNG
    IMAGEMODE RGBA
    FORMATOPTION "TRANSPARENT=ON"
    #TRANSPARENT ON
  END
-----Mensaje original-----
De: Brent Fraser [mailto:bfraser at geoanalytic.com]
Enviado el: martes, 19 de febrero de 2008 18:38
Para: Hans Castorp
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] AGG_Q + raster problem
Hans,
  I did a "gdalinfo" on the image you attached, it has only
32 colors defined (so it looks "bad"):
Driver: PNG/Portable Network Graphics
Size is 256, 256
Coordinate System is `'
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  256.0)
Upper Right (  256.0,    0.0)
Lower Right (  256.0,  256.0)
Center      (  128.0,  128.0)
Band 1 Block=256x1 Type=Byte, ColorInterp=Palette
  NoData Value=0
  Color Table (RGB with 32 entries)
    0: 239,235,231,0
    1: 126,63,0,255
    2: 189,189,63,255
    3: 126,126,189,255
    4: 63,126,126,255
    5: 189,252,189,255
    6: 63,0,63,255
    7: 0,63,63,255
    8: 63,63,126,255
    9: 252,189,252,255
   10: 126,63,126,255
   11: 189,252,126,255
   12: 189,126,189,255
   13: 63,0,0,255
   14: 189,126,63,255
   15: 126,189,63,255
   16: 0,63,0,255
   17: 252,189,126,255
   18: 252,189,189,255
   19: 126,189,126,255
   20: 252,252,189,255
   21: 189,126,126,255
   22: 0,0,0,255
   23: 63,126,63,255
   24: 189,189,189,255
   25: 252,252,252,255
   26: 63,63,0,255
   27: 189,189,126,255
   28: 126,63,63,255
   29: 126,126,126,255
   30: 63,63,63,255
   31: 126,126,63,255
Are you sure this is the image produced from your new map
file (it's not an old one left over from an earlier attempt
is it)?
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
Sent: Tuesday, February 19, 2008 10:25 AM
Removing DITHER statement I get an "8 bit like" image, as
you can see in the
attachment...
I think I'm going crazy with all this trouble...
Enviado el: martes, 19 de febrero de 2008 18:07
Para: Hans Castorp
Hans,
  Try removing  PROCESSING "DITHER=YES" from the ORTOFOTO
layer definition.  I think it is converting the 24-bit input
raster to 8-bit before it renders it to the 24-bit output
image.
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
Sent: Tuesday, February 19, 2008 9:36 AM
Hi, Brent
I'm using mapserver 5.0.0 for Windows.
I have no problems with vectorial data (shapefiles). The
rest of my mapfile
is like this:
MAP
  NAME 'gmap'
  SIZE 800 600
  STATUS ON
  EXTENT 559273 4709373 584263 4737543
  FONTSET cartografia.fonts
  TRANSPARENT TRUE
  IMAGECOLOR 239 235 231
  SHAPEPATH "C:\ms4w\apps\ka-map-1.0\mapdata\xxxxx\"
  IMAGETYPE AGGA
  CONFIG "PROJ_LIB" "C:\ms4w\proj\nad\"
  WEB
IMAGEPATH 'C:\ms4w\apps\ka-map-1.0\htdocs\xxxxx\tmp\'
IMAGEURL 'C:\ms4w\apps\ka-map-1.0\htdocs\xxxxx\tmp\'
  END
  PROJECTION
"init=epsg:23029"
  END
  REFERENCE
SIZE 193 236
'C:\ms4w\apps\ka-map-1.0\htdocs\xxxxx\css\img\keymap.gif'
  END
LEGEND
STATUS ON
KEYSPACING 5 10
KEYSIZE 20 12
IMAGECOLOR 255 255 255
LABEL
  TYPE TRUETYPE
  FONT bluehigh
  COLOR 0 0 0
  OUTLINECOLOR 254 254 254
  SIZE 12
END
END
  OUTPUTFORMAT
    NAME 'AGGA'
    DRIVER AGG/PNG
    IMAGEMODE RGBA
    #TRANSPARENT ON
  END
#SYMBOL DEFINITION
  WEB
     HEADER "tlg_header.xml"
     FOOTER "tlg_footer.xml"
  END
#MDT
LAYER
NAME "MDT"
STATUS DEFAULT
GROUP "MDT"
TYPE raster
OPACITY 75
#PROCESSING "SCALE=AUTO"
CLASS
MINSCALE 15000
END
DATA "mdtxxxxx2.tif"
END
#ORTOFOTO
LAYER
NAME "ORTOFOTO"
STATUS DEFAULT
GROUP "ORTOFOTO"
TYPE raster
DATA "ortoxxxxx.ecw"
CLASS
MAXSCALE 15000
END
END
 #LAYERS DEFINITION
END ## end Map
Enviado el: martes, 19 de febrero de 2008 16:46
Para: Hans Castorp
Hans,
  That is stange.  I've tested mapserver 5.0.0. Beta 4 (it's
the only v5 I've got compiled) and it gives me a 24 bit
color image.  What version of Mapserver are you using?  Can
you send your entire map file?
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
To: <bfraser at geoanalytic.com>
Sent: Tuesday, February 19, 2008 2:21 AM
Yes, I'm still getting a quantized image using this
statement:
  OUTPUTFORMAT
   NAME 'AGG_PNG'
   DRIVER AGG/PNG
   IMAGEMODE RGB
  END
Enviado el: lunes, 18 de febrero de 2008 21:37
Para: Hans Castorp
Asunto: RE: [mapserver-users] AGG_Q + raster problem
So when you remove all the quantize options, you still get a
quantized
image on output?  Using something like:
  OUTPUTFORMAT
   NAME 'AGG_PNG'
   DRIVER AGG/PNG
   IMAGEMODE RGB
  END
> This, by example
> De: Guillaume Sueur
[mailto:guillaume.sueur at neogeo-online.net]
> Enviado el: lunes, 18 de febrero de 2008 19:04
> Para: Hans Castorp; mapserver-users at lists.osgeo.org
> what's the result in standard AGG mode ?
> Hans Castorp a écrit :
>> The result is the same with or without this line...
>> De: Guillaume Sueur
>> Enviado el: lunes, 18 de febrero de 2008 18:59
>> Para: Hans Castorp
>> quantize_colors=255 is maybe the reason why your colors
are reindexed on
>> a 256 colors palette.
>>> Thanks Brent, but there is a mistake, the example I
attached is not the
>>> mapservers original output: I have prepared it and give
....gif extensión.
>>> This is the way I configure my output:
>>>   OUTPUTFORMAT
>>>     NAME 'AGG_Q'
>>>     DRIVER AGG/PNG
>>>     IMAGEMODE RGBA
>>>     FORMATOPTION "QUANTIZE_FORCE=ON"
>>>     FORMATOPTION "QUANTIZE_DITHER=OFF"
>>>     FORMATOPTION "QUANTIZE_COLORS=255"
>>>   END
>>> Thanks in advance.
>>> Enviado el: lunes, 18 de febrero de 2008 18:17
>>> Para: Hans Castorp
>>> Hans,
>>>   GIF supports only 256 colors.  Use PNG (or JPG) for an
output format.
>>> Brent Fraser
>>>> Hi to all,
>>>> I'm trying to publish a cartography using both
vectorial and raster
>>>> layers.
>>>> I'm using mapserver 5 and agg_q as output format. There
is no problem
>>>> about
>>>> vectorial files (shapefiles): all work fine.
>>>> The only problem I'm having is trying to publish some
raster stuff: an
>>>> aerial photo (.geotiff) and a digital terrain model
(.ecw). I'm not
>>>> capable
>>>> to make the output showing real colours; there is an
example attached
>>>> to
>>>> this mail (an aerial photo).
>>>> My mapfile looks in this way:
>>>> LAYER
>>>>         NAME "MDT"
>>>>         STATUS DEFAULT
>>>>         GROUP "MDT"
>>>>         TYPE raster
>>>>         DATA "mdt.tif"
>>>>         CLASS
>>>>                MINSCALE 15000
>>>>         END
>>>> END
>>>> LAYER
>>>>         NAME "ORTOFOTO"
>>>>         STATUS DEFAULT
>>>>         GROUP "ORTOFOTO"
>>>>         TYPE raster
>>>>         DATA "ortofoto.ecw"
>>>>         CLASS
>>>>                MAXSCALE 15000
>>>>         END
>>>> END
>>>> What I have to do to solve this?
>>>> Thanks in advance to everyone.
>>>> Hans Castorp
>>> No virus found in this incoming message.
>>> Checked by AVG Free Edition.
>>> Version: 7.5.516 / Virus Database: 269.20.7/1285 -
Release Date:
>> 18/02/2008
>>> 5:50
>>> No virus found in this outgoing message.
Release Date:
>> 18/02/2008
>>> 5:50
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Guillaume SUEUR
> Expert SIG et OpenSource
> NEOGEO
> 46 RUE MATABIAU
> 31000 TOULOUSE
> 06 74 91 95 20
> Site web : http://www.neogeo-online.net
> Version: 7.5.516 / Virus Database: 269.20.7/1285 - Release
Date:
> 18/02/2008
> 5:50
Date:
> 18/02/2008
> 5:50
Version: 7.5.516 / Virus Database: 269.20.7/1286 - Release
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
