[mapserver-users] Netcdf / WCS
vincent.thierion at ema.fr
Thu Feb 21 04:19:50 EST 2008
Hello,
I'm not expert on OWS, but serve netCDF files within WCS seems not
totally achieve. The
case of Barker concerns a set of netCDF files.
The Galeon project is trying to develop this issue :
http://galeon-wcs.jot.com/Implementation%20Progress%20Page.
For my case, i think the best way is to create one netCDF file per
time step or to create
a script to generate TIF files and after serves them.
Best Regards
Vincent
Steve Lime <Steve.Lime at dnr.state.mn.us> a écrit :
> I need to think about this. For some reason I remember one of the test
> cases being
> just like this although with not so many bands. As the cobwebs clear I
> believe this
> was started but not completed. There's even a BANDSITEM member of the
> layer object
> defined in the source. This would allow definition of a column to map a
> temporal value
> to a particular band within a larger image. I'm thinking it's probably
> not far from functioning.
> Steve
>>>> On 2/19/2008 at 10:08 AM, in message <47BAFEE1.60508 at pobox.com>,
> Frank
> Warmerdam <warmerdam at pobox.com> wrote:
>> vincent wrote:
>>> Hello,
>>> I would like to create Web Coverage Service from one netCDF file in
>>> following
> http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
>>> My netCDF store rainfall matrix every five minutes in the "pluie"
>>> variable. This the CDL :
>>> dimensions:
>>> time = UNLIMITED; // (496 currently) // (has coord.var)
>>> x = 50; // (has coord.var)
>>> y = 50; // (has coord.var)
>>> variables:
>>> int Lambert_Conformal;
>>> :grid_mapping_name = "lambert_conformal_conic";
>>> :standard_parallel = 43.20317, 44.99683; // double
>>> :longitude_of_central_meridian = 2.337229; // double
>>> :latitude_of_projection_origin = 44.1; // double
>>> :false_easting = 600.0; // double
>>> :false_northing = 3200.0; // double
>>> :_CoordinateTransformType = "Projection";
>>> :_CoordinateSystems = "ProjectionCoordinateSystem";
>>> :_CoordinateAxes = "y x";
>>> :_CoordinateAxisTypes = "GeoX GeoY";
>>> * double pluie(time=496, y=50, x=50);*
>>> * :units = "mm/h";*
>>> * :long_name = "Intensité de pluie";*
>>> * :coordinates = "lat lon";*
>>> * :grid_mapping = "Lambert_Conformal";*
>>> * :_CoordinateSystems = "ProjectionCoordinateSystem
>> LatLonCoordinateSystem";*
>> Vincent,
>> Because GDAL treats this array as a single dataset having 496 bands,
> I don't
>> believe there is a way to properly create a tileindex with one entry
> per
>> time slice, referring back directly to that band though this is
> something
>> that
>> I think was discussed at one point.
>> You *can* serve the pluie array, but it will be represented as having
> 496
>> bands along a dimension called Band instead of time.
>> Hopefully Steve will correct me if I am wrong. What would be nice
>> is a way to have WCS (and raster rendering in general) potentially
>> override the BANDS= processing option with information read from a
>> tile index, and then update the gdaltindex program accordingly to
>> generate such results. This shouldn't - in theory - be too hard to
>> implement.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Ce message a ete envoye par le serveur IMP de l'EMA.
