Antwort: Re: [mapserver-users] Strange line in picture
umn-ms at hydrotec.de umn-ms at hydrotec.de
Sun Feb 24 13:04:56 EST 2008
I repeated the test  with 5.0.2.
Error doesn't occure. Seems to be solved.
Bye
Benedikt Rothe
Gregor Mosheh <gregor at hostgis.com> schrieb am 24.02.2008 18:23:10:
> umn-ms at hydrotec.de wrote:
> > In some cases Mapserver produces an unwanted and strange horizontal
line
> > at the bottom of a map, if a point is rendered near  the bottom.
> If the answer is the same as when I noted this some months ago:
> That's a known GD+Mapserver bug. But strangely I didn't find this bug in
> the MS Trac; not that I looked very hard.
> Try AGG, or grab the latest Subversion version of Mapserver. Then again,
> the fix may be in 5.0.1 by now.
> Gregor Mosheh / Greg Allensworth, BS, A+
> System Administrator
> HostGIS cartographic development & hosting services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
>   only if you can restore." - AMANDA
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080224/136633d4/attachment.html
