[MAPSERVER-USERS] postgres transaction warnings
rich.fromm
nospam420 at yahoo.com
Thu Feb 28 19:35:15 EST 2008
rich.fromm wrote:
> In my postgres log file
> (/var/log/postgresql/postgresql-8.1-main.log), I see a TON of messages
> like
> the following:
> 2008-02-28 13:48:08 PST WARNING: there is already a transaction in
> progress
> 1) In the mappostgis.c source, I see a number instances of transactions
> starting, via "BEGIN" statements. There are also a number instances of
> transactions being canceled, via "ROLLBACK" statements, when something
> goes
> wrong. However, I can not find a single instance of a transaction
> being
> normally closed, via an "END" statement. Is the code perhaps somehow
> leaking transaction resources? Or maybe there's a genuine reason that
> "END" statements aren't needed? Maybe something in some of the PQfoo()
> methods indirectly accounts for this? I haven't looked at it in much
> detail, but I don't see anything in the libpq docs
> (http://www.postgresql.org/docs/8.1/static/libpq-exec.html) that
> suggests
> this.
> 2) In my situation, the database is effectively read only, because updates
> will happen infrequently and always in bulk and offline. So I would
> think
> that transactions are totally unnecessary, since any individual read
> statement will by definition see a consistent view of the database.
> Transactions aren't going to help at all, and would I think only serve
> to
> consume resources and possibly adversely affect performance. I can see
> how
> they might be needed in cases where updates were expected, but in my
> case I
> would like to be able to disable them. Is there any option to do this?
> I
> assume no. But even if that is the case, is this analysis correct, and
> might such an option be a useful feature to provide?
Did some more looking around on my own. Regarding (1), something similar
seems to have been reported previously on the old mailing list:
http://www.nabble.com/Segmentation-fault---mapserver---postgis-to12653945.html#a12674499
I think bug 2497 is at least partially addressing this:
http://trac.osgeo.org/mapserver/ticket/2497
I can try locally applying the diff there, but I'm still a bit confused.
Just moving the BEGIN and not inserting an END may solve a problem of
unnecessary duplicate transactions, but I still don't understand how the
transaction gets properly ended.
Oh yeah, I do have for each LAYER:
PROCESSING "CLOSE_CONNECTION=DEFER"
I haven't found anything yet addresing (2).
- Rich
View this message in context: http://www.nabble.com/postgres-transaction-warnings-tp15749333p15749520.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
