[mapserver-users] symbology showing line direction
Adam Feidt
afeidt at edenprairie.org
Fri Feb 29 09:42:42 EST 2008
David,
Below is my Layer definition. I've tried a truetype symbol and
label with the ANGLE parameter set to AUTO or FOLLOW. Neither case
pointed out actual shapefile line direction. I'm reading an ESRI
shapefile so there is no specific column for line direction.
LAYER
NAME 'Utilities Sanitary Lines'
DATA './UtilitiesSanitaryLines.shp'
TYPE LINE
STATUS DEFAULT
CLASSITEM "Function"
CLASS
NAME 'Main'
EXPRESSION ""
STYLE
COLOR 85 255 0
SYMBOL "plainline"
SIZE 2
END
END # end class
CLASS
NAME 'Low Pressure'
EXPRESSION "Low Pressure"
STYLE
COLOR 255 85 0
SYMBOL "plainline"
SIZE 2
END
END # end class
CLASS
NAME 'Sub Trunk'
EXPRESSION "Sub Trunk"
STYLE
COLOR 85 255 0
SYMBOL "plainline"
SIZE 2
END
END # end class
CLASS
NAME 'Trunk'
EXPRESSION "Trunk"
STYLE
COLOR 112 168 0
SYMBOL "plainline"
SIZE 2
END
END # end class
CLASS
NAME 'Force Main'
EXPRESSION "forcemain"
STYLE
COLOR 255 170 0
SYMBOL 'dashed1'
SIZE 2
END
END # end class
CLASS
NAME 'Private'
EXPRESSION "private"
STYLE
COLOR 161 33 240
SYMBOL 'plainline'
SIZE 2
END
END # end class
END #end layer
Adam M. Feidt
GIS Coordinator
City of Eden Prairie
8080 Mitchell Rd
Eden Prairie, MN 55344
phone# 952-949-8443
fax# 952-949-8334
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Friday, February 29, 2008 8:19 AM
To: Adam Feidt; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] symbology showing line direction
Adam,
What does your layer definition, with the classes look like?
Does your data have the direction column properly populated for all
records?
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adam Feidt
Sent: Friday, February 29, 2008 8:14 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] symbology showing line direction
I'm working in a GeoMoose application and trying to
display utility lines with the correct line direction via some arrow
character or symbol. I've had no luck so far. I've successfully
labeled my lines with a truetype font character by defining the TEXT ">"
parameter in the CLASS object. I've also tried a pixelmap symbol
definition using a .gif file. Both appear to work at first, but when
you compare it to the actual line direction it isn't true in all cases.
Has anybody found a way to accomplish this? I would appreciate if you
could send me any examples.
Adam M. Feidt
GIS Coordinator
8080 Mitchell Rd
phone# 952-949-8443
fax# 952-949-8334
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080229/836d9b5e/attachment-0001.html
