[mapserver-users] symbology showing line direction
G. Allegri giohappy at gmail.com
Fri Feb 29 12:49:16 EST 2008
David, I had your opinion too, but Adam seems to have solved it. Adam,
do you confirm that you can display correctly directions?
2008/2/29, Fawcett, David <David.Fawcett at state.mn.us>:
> Adam,
> I am quite sure that MapServer is not going to read the line topology.  To
> display direction, you will need to add an attribute for flow direction and
> populate it.  You would then use an expression for each class that combined
> both the pipe type and the direction.  (Maybe use -1 and 1 for values?)
> Something like ('[FUNCTION]' = 'Main' AND [DIRECTION] = -1)
> I haven't tested this.  Note the difference in quoting for string fields vs
> number fields.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf
> Of Adam Feidt
> Sent: Friday, February 29, 2008 8:43 AM
> To: Fawcett, David; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] symbology showing line direction
> David,
>      Below is my Layer definition.  I've tried a truetype symbol and label
> with the ANGLE parameter set to AUTO or FOLLOW.  Neither case pointed out
> actual shapefile line direction.  I'm reading an ESRI shapefile so there is
> no specific column for line direction.
> LAYER
>             NAME 'Utilities Sanitary Lines'
>             DATA './UtilitiesSanitaryLines.shp'
>             TYPE LINE
>             STATUS DEFAULT
>             CLASSITEM "Function"
>             CLASS
>                   NAME 'Main'
>                   EXPRESSION ""
>                   STYLE
>                     COLOR 85 255 0
>                     SYMBOL "plainline"
>                     SIZE 2
>                   END
>             END # end class
>             CLASS
>                   NAME 'Low Pressure'
>                   EXPRESSION "Low Pressure"
>                   STYLE
>                     COLOR 255 85 0
>                     SYMBOL "plainline"
>                     SIZE 2
>                   END
>             END # end class
>             CLASS
>                   NAME 'Sub Trunk'
>                   EXPRESSION "Sub Trunk"
>                   STYLE
>                     COLOR 85 255 0
>                     SYMBOL "plainline"
>                     SIZE 2
>                   END
>             END # end class
>             CLASS
>                   NAME 'Trunk'
>                   EXPRESSION "Trunk"
>                   STYLE
>                     COLOR 112 168 0
>                     SYMBOL "plainline"
>                     SIZE 2
>                   END
>             END # end class
>             CLASS
>                   NAME 'Force Main'
>                   EXPRESSION "forcemain"
>                   STYLE
>                     COLOR 255 170 0
>                     SYMBOL 'dashed1'
>                     SIZE 2
>                   END
>             END # end class
>             CLASS
>                   NAME 'Private'
>                   EXPRESSION "private"
>                   STYLE
>                     COLOR 161 33 240
>                     SYMBOL 'plainline'
>                     SIZE 2
>                   END
>             END # end class
>       END #end layer
> Adam M. Feidt
> GIS Coordinator
> City of Eden Prairie
> 8080 Mitchell Rd
> Eden Prairie, MN 55344
> phone# 952-949-8443
> fax# 952-949-8334
> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> Sent: Friday, February 29, 2008 8:19 AM
> To: Adam Feidt; mapserver-users at lists.osgeo.org
> Adam,
> What does your layer definition, with the classes look like?
> Does your data have the direction column properly populated for all records?
> David.
> Of Adam Feidt
> Sent: Friday, February 29, 2008 8:14 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] symbology showing line direction
>       I'm working in a GeoMoose application and trying to display utility
> lines with the correct line direction via some arrow character or symbol.
> I've had no luck so far.  I've successfully labeled my lines with a truetype
> font character by defining the TEXT ">" parameter in the CLASS object.  I've
> also tried a pixelmap symbol definition using a .gif file.  Both appear to
> work at first, but when you compare it to the actual line direction it isn't
> true in all cases.  Has anybody found a way to accomplish this?  I would
> appreciate if you could send me any examples.
> Adam M. Feidt
> GIS Coordinator
> 8080 Mitchell Rd
> phone# 952-949-8443
> fax# 952-949-8334
>  mapserver-users mailing list
>  http://lists.osgeo.org/mailman/listinfo/mapserver-users
