Mapserver 5.0.0 and ANGLE for label class
Luca Manganelli
luca76 at GMAIL.COM
Wed Jan 2 09:07:13 EST 2008
Hi, I have a field with angles in degrees. The attached mapfile
doesn't rotate the label. I used this in Mapserver 4.x without
problems:
LAYER
TYPE POINT
TEMPLATE void
CLASS
END
LABEL
TYPE TRUETYPE
ANTIALIAS TRUE
FONT arial
SIZE 20
MINSIZE 4
MAXSIZE 30
ANGLE [field]
FORCE true
OFFSET 0 0
POSITION cc
PARTIALS TRUE
COLOR 255 0 0
END
END
How can I fix this?
