WFS request options
Josh Livni
mailing_lists at UMBRELLACONSULTING.COM
Fri Jan 4 09:58:56 EST 2008
This doesn't answer you question exactly, but have you considered using
a WMS getFeatureInfo request instead? Then you can use a simple
template.html to decide which attributes you want to return for later
parsing.
I've done this a few times myself with Google Maps.
-Josh
nelson guda wrote:
> Hi all,
> I have an odd request regarding WFS capabilities. Is it possible to
> have a WFS mapserver request return gml results without the geometry
> data?
> I know that this seems odd, but it makes sense for what I am doing. I
> am using a WMS overlay to serve tiles for a large dataset to an
> overlay on google maps. In order to query specific polygons from that
> dataset (a shapefile), I am using a WFS GetFeature request. All I
> need is the id and other parameters of the feature, but not the
> geometry data (because it is already there from the WMS. Right now I
> am just parsing out the info I need from the gml at the server level,
> but it would be much faster if I could get the WFS to return only the
> feature info minus the geometry data. Is this possible?
> Thanks, and thanks for your previous help.
> nelson
