Unusual Fonts (resend, image too big)
Howard Butler hobu.inc at GMAIL.COM
Sun Jan 6 23:47:00 EST 2008
Neil,
Looking through your post, and by virtue of using the SDE 9.2 plugin,
I'll assume you are connecting to ArcSDE 9.2.
First, what does the output of sdetable -o describe say for your
SpeciesLabel column about the column data type?  Is it NSTRING?
Here's the story on unicode characters and MapServer+ArcSDE 9.2...  As
long as your characters aren't wide format, ie UTF-8'ish, they should
be printable and usable with the iconv support in GD/AGG.  If they are
wide, however, they are garishly converted down to UTF8.  My rational
for this approach is that many of the Arc tools emit unicode columns
for string data in 9.2 SDE layers, but much of the time, people don't
want/need that, and they are storing ASCII or LATIN-type data in them
anyway.  MapServer internally does not support wide characters,
however, so there are some significant limitations in this approach,
and if MapServer is converting your wide characters down to UTF8, you
are pretty much screwed.  Another huge limitation of this approach is
that it is really only usable for labeling things.  You cannot use any
expressions on NSTRING columns in ArcSDE with MapServer and expect to
do anything.
You shouldn't have to specify an encoding for the SDE layer because
any NSTRING columns (which SDE stores as UTF-16) are smashed down to
UTF8, which iconv/GD/AGG can render and deal with.
All of this blather says that the unicode support for MapServer is
very immature, and if you can reload your ArcSDE layer to use regular
string columns in your ArcSDE layers, things should work much smoother
and as expected.
Howard
On Jan 6, 2008, at 4:12 PM, Neil Fincham wrote:
> Hi Ed,
> 	Thanks for the quick reply, a picture says 1000 words so I have
> done a
> screen dump out of ArcVIEW for you.
> 	I have tried a few different fonts and a few different string fields
> from the SDE and get the same result with the string's, the integers
> and
> <Null>'s render fine and using a shape file exported directly out of
> the
> SDE also works fine.
> Very puzzling
> Neil
> Ed McNierney wrote:
>> Neil -
>> Could you give an example of the text in one of the SpeciesLabel
>> fields?  What alphabet, character set, and language is the
>> SpeciesLabel field stored in?  If you switch to a different FONT
>> does the output change?
>> At first glance you appear to have code points in the label that
>> are not representable in the selected font.  That might not be the
>> problem, but it's worth eliminating - hence my questions above.
>> 	- Ed
>> Ed McNierney
>> Chief Mapmaker
>> Demand Media / TopoZone.com
>> 73 Princeton Street, Suite 305
>> North Chelmsford, MA  01863
>> Phone: 978-251-4242, Fax: 978-251-1396
>> ed at topozone.com
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-
>> USERS at LISTS.UMN.EDU] On Behalf Of Neil Fincham
>> Sent: Sunday, January 06, 2008 3:37 PM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] Unusual Fonts
>> Hi all,
>> 	I am really enjoying my first delve into mapping and like to say
>> thanks for the great software.
>> 	I am havering a bit of a problem and I am sure it is something
>> easy, I am getting unusual fonts rendering using SDE.  It works
>> fine with the shape files but with SDE the text parts come out
>> wrong.  I have attached a sample.
>> Here are some bits from my mapfile;-
>> OUTPUTFORMAT
>> NAME 'AGG'
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> END
>> LAYER
>>  NAME LandUnit
>>  METADATA
>>    "DESCRIPTION"   "Land Unit"
>>    "RESULT_FIELDS" "ForestCode Description"
>>  END
>>  TYPE POLYGON
>>  STATUS ON
>>  CONNECTIONTYPE PLUGIN
>>  PLUGIN "/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
>>  CONNECTION "palustris,port:5155,d,ms_user,p4ss\/\/ord"
>>  DATA "d.DBO.LandUnit,SHAPE,SDE.DEFAULT"
>>  TOLERANCE 5
>>  TEMPLATE "ttt_query.html"
>>  CLASS
>>    SYMBOL 0
>>    COLOR 255 255 255
>>    OUTLINECOLOR 0 0 0
>>    TEXT ([SpeciesLabel] [YOE] [AreaHA]ha)
>>    LABEL
>>      FONT "vera"
>>      TYPE truetype
>>      SIZE 8
>>      BUFFER 1
>>      COLOR 0 0 0
>>      BACKGROUNDCOLOR 255 255 255
>>      WRAP " "
>>      ENCODING UTF-16
>>    END
>>  END
>> END # Layer
>> 	The [SpeciesLabel] is the one with the problem, the "[YOE]
>> [AreaHA]ha"
>> are numbers and render correctly.  I have tried various ENCODING
>> types to no avail.
>> Thanks for your time
>> Neil
> <fonts.jpg>
