Example 1.9: Interactive Maps and the Browse Mode NOT WORKING
faiza zaidi faiza_nov at HOTMAIL.COM
Mon Jan 7 06:25:32 EST 2008
hi,as i am new to the mapserver, and find it good for the pdf outputs. i have installed the ms4w package and tutorial for mapserver version 5. i have tried the tutorial as well, but getting some problem.
i have copied my mapfile and an html page on the path "C:\ms4w\Apache\htdocs\chk" and got it running in the browser as "http://localhost:82/chk/example1-9.html". but the problem is with browser output. i m unable to see the image when the mode is set to browse. i have followed the link
http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-9.map&layer=states&layer=modis
in the log file i am getting an error "[Mon Jan 07 10:39:28 2008] [error] [client 127.0.0.1] File does not exist: C:/ms4w/Apache/htdocs/chk/[img], referer: http://localhost:82/chk/example1-9.html"
when i checked the tmp\ms_tmp\ i found no image there.
 also when i click on the place of the image it give me the error :
"msEvalRegex(): Regular expression error. String ([map]) failed expression test."
my mapfile is:
MAP  NAME           EX1.9_  IMAGETYPE      PNG24  EXTENT 246033.25 53055.59765625 250754.625 57199.203125  SIZE           400 300    WEB    TEMPLATE  'C:/ms4w/Apache/htdocs/chk/example1-9.html'    IMAGEPATH 'c:/ms4w/tmp/ms_tmp/'    IMAGEURL  'c:/ms_tmp/'  END    # Start of LAYER DEFINITIONS ---------------------------------------------  LAYER # States polygon layer begins here    NAME         states    CONNECTIONTYPE postgis    CONNECTION "user=kk password=kk dbname=kk host=localhost port=5432"    DATA "geom from topographicarea"    TYPE POLYGON    STATUS       OFF
CLASS      NAME       "land"EXPRESSION ('[theme]' = 'Land')
     STYLE        COLOR         255 0 0        OUTLINECOLOR 255 0 0      END    END    END # States polygon layer ends here  # End of LAYER DEFINITIONS
END # end of mapfile -------------------------------#
my html page is:
<html>  <head>    <title>MapServer 5.x Tutorial</title>    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">    <link type="text/css" rel="stylesheet" href="ms35.css" />  </head>
  <body bgcolor="#FFFFFF" text="#000000">
  <table align="center" width="680" border="0">    <tr>      <td>        <h3 align="center">          Example 1.9: Interactive Maps and the Browse Mode        </h3>        <div align="center">
   <img border="1" src="/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/chk/example1-9.map&layer=states&mode=map" />        </div>        <p align="left">The map above was created in &quot;map&quot; mode. It is          a static map (it doesn't change when you click on it).        </p>
        <!-- START OF MAPSERVER FORM -->        <form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe">          <!-- HIDDEN MAPSERVER CGI VARIABLES -->          <input type="hidden" name="map" value="[map]">          <input type="hidden" name="imgext" value="[mapext]">          <input type="hidden" name="imgxy" value="[center]">   <input type="hidden" name="zoom" value="0">        <input type="hidden" name="layer" value="states">  <input type="hidden" name="mode" value="browse">   <div align="center">     <table border="1" cellpadding="0" cellspacing="0">       <tr>                <td>    <!-- THE INTERACTIVE, DYNAMICALLY CREATED MAP -->    <input type="image" name="img" src="[img]"                    width="400" height="300">  </td>              </tr>     </table>   </div> </form>        <!-- END OF MAPSERVER FORM --> </table></body></html>
can you please tell where i am getting problem in the form section of my html page. the static map image works fine. thanks for any help. zaidi.
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080107/a10d140d/attachment.html
