wide lines not complete at the edges
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Jan 7 18:04:54 EST 2008
rich.fromm wrote:
> Steve Lime wrote:
>> Can you post your mapfile and a small data sample?
> The map files are in the posting starting this thread:
> http://www.nabble.com/wide-lines-not-complete-at-the-edges-to14609249.html
> My data is a large dataset from navteq that I have imported into postgis.
> I'll have to look into both what would be needed to do to trim it down, and
> whether or not my license allows me to redistribute it at all (I'm guessing
> not). Although I probably could generate a test case with synthetic data,
> although that would require me researching a little bit about how the low
> level data is stored.
Rich,
Based on looking at you images, I would just create a simple table in
postgis and put in a few lines in a 0,0,5,5 space and create a simple
one layer mapfile to display that on a simple 500x500 image. Using
number like this make the math trivial. you can then pgsql2shp dump the
table as a shapefile, and change you DATA statement and zip the mess up
and attach it to a bug.
Let me know is you need some more specific instructions or get stuck on
doing this. This looks like a bug that need to get fixed.
-Steve W
