Please help me SDE C# asp.net and mapserver connection
problem....
Tamas Szekeres
szekerest at GMAIL.COM
Tue Jan 15 05:58:01 EST 2008
Yatendra,
It seems the ASP runtime is not able to load the plugin dll. You might
want try to copy this dll into the same directory where your ASP.NET
host process is running. If the dll can be loaded from the same
directory then it might be a security related issue.
Another problem is that the SDE plugin is compiled as a 32 bit image
and the 64 bit version of the .NET framework cannot load it,
definitely.
Best regards,
Tamas
2008/1/15, yatendra <yatendra.jaiswal at gmail.com>:
> Hi to all,
> I am trying to connect mapserver with SDE.
> I have successfully connected in html(Map file working fine).
> Now i am trying this asp.net connetion with same map file.
> i followed all instruction and source codes given in tutorial
> http://www.paolocorti.net/public/wordpress/index.php/2006/09/20/mapserver-tutorial-for-c-mapscript-asp-net/.
> application is giving error while running. and error is as follows in
> MapStream.aspx.cs
> msDrawMap(): Image handling error. Failed to draw layer named
> 'TILE'.;loadCustomLayerDLL: General error message. Failed to load dynamic
> Layer LIB:
> C:\ms4w\Apache\specialplugins\msplugin_sde_92.dll;msGetSymbol(): General
> error message. Can't load requested dynamic library:
> PLease help me out to solve this problem.
> Why i am getting this problem.
> Can anyone explain please…
> Thanks Regards
> Yatendra
> View this message in context: http://www.nabble.com/Please-help-me-SDE-C--asp.net-and-mapserver-connection-problem....-tp14749790p14749790.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
