Problem Oracle Spatial
Till Adams
adams at TERRESTRIS.DE
Tue Jan 15 08:13:51 EST 2008
Fernando,
did you laos try this:
http://mapserver.gis.umn.edu/docs/howto/Configure%20Oracle%20and%20UMN
Our main problem was to let apache know the env-variable of oracle.
Regards, Till
> Hi,
> What is the error that Mapserver returns? Some ora-* error, ou a
> blank page?
> About the Apache, the user that runs the apache service has the
> read permission in the Oracle home directory? Did you installed the
> OCI (Oracle Call Interface) from the Oracle installation?
> Best regards.
> Fernando Simon
> SUBSCRIBE MAPSERVER-USERS Bego D. wrote:
>> Hello
>> I´m new with Mapserver.
>> I have set up an application with locals files without problems but
>> now i want connect with Oracle Spatial for example with one of my
>> layers.
>> I follow all the steps in the
>> http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto but it
>> doesnt work. The other layers, from MapInfo, are working rigth.
>> My mapfile is:
>> LAYER NAME "CARRETERA" STATUS ON TYPE POLYGON CONNECTIONTYPE
>> oraclespatial
>> CONNECTION "user/pasword at bbdd" DATA "GEOLOC FROM CARRETERA using
>> SRID 82337"
>> DUMP TRUE
>> CLASS STYLE OUTLINECOLOR 255 0 0 END END END
>> And C:\ms4w\Apache\conf\httpd.conf
>> SetEnv ORACLE_SID bbdd
>> SetEnv TNS_ADMIN "c:/oracle/product/10.2.0/client_1/NETWORK/ADMIN"
>> SetEnv ORACLE_HOME "c:/oracle/product/10.2.0/client_1"
>> Thanks in advance
terrestris ist umgezogen!
Die neue Adresse ab 01.07.2007 lautet:
Irmintrudisstraße 17, 53111 Bonn
http://www.terrestris.de
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
