WFS requests ignore PostGIS columns beside the Geometry and ID column
sg1 sglawi at WEB.DE
Tue Jan 15 11:14:22 EST 2008
Hi everybody,
I use the ms4w package version 2.2.6.
I tried your suggestions, but nothing helped, until - just because of pure
frustration - i changed the ' signs to "
So instead of 'gml_include_items' 'all'
it's
"gml_include_items" "all" now
And this works!
I don't know exactly why, maybe one of you can tell me if there is  a
significant difference in using different quotation marks?
I knew it had to be a obvious error, but that is just...
Thanks for your time and help!
sg1
Kralidis,Tom [Burlington] wrote:
> What version of MapServer are you using?
> As well, I see that you have set 'gml_include_items' to 'all '.  If you
> remove the trailing space (i.e. 'all'), does that help?
> Failing this, I suggest you submit a testcase offline (minimal
> mapfile/sample data), which I can help you with.
> ..Tom
View this message in context: http://www.nabble.com/WFS-requests-ignore-PostGIS-columns-beside-the-Geometry-and-ID-column-tp14766031p14841679.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
