map_resolution in 5.0 does not work
Fawcett, David
David.Fawcett at STATE.MN.US
Fri Jan 18 08:59:12 EST 2008
Have you looked at the 5.0 migration guide?
http://trac.osgeo.org/mapserver/browser/tags/rel-5-0-0/mapserver/MIGRATI
ON_GUIDE.TXT
If not, take a look at the section titled, 'URL configuration changes'.
I don't know for sure, but you might want to try something like
map.resolution=25
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bart van den Eijnden
Sent: Friday, January 18, 2008 6:03 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] map_resolution in 5.0 does not
work
Hi list,
why does the following fail against Mapserver 5.0, it used to
work in previous version:
map_resolution=25, for instance:
http://test.intranet.rijkswaterstaat.nl/services/geoservices/basispakket
/dtb?map_resolution=25&LAYERS=AAA161&REQUEST=GetMap&SERVICE=WMS&FORMAT=i
mage%2Fpng&STYLES=default&HEIGHT=1260&VERSION=1.1.1&SRS=EPSG:28992&WIDTH
=1530&BBOX=%2D64210%2E0044897549%2C273591%2E761008437%2C364210%2E0044897
55%2C626408%2E238991563&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.
se_inimage
Mapserver 5.0 returns:
getDouble(): Symbol definition error. Parsing error near
(25):(line 1)
TIA.
Best regards,
Bart
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080118/2cce1780/attachment.html
