map_resolution in 5.0 does not work
Bart van den Eijnden
bartvde at GMAIL.COM
Fri Jan 18 09:44:24 EST 2008
Hi David,
I did read it, but could not really find a clue in it for my problem.
Are the . not typos? There are also _ examples still in there.
Anyways, I tried map.resolution=25 to no avail.
Best regards,
Bart
On Jan 18, 2008 2:59 PM, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> Have you looked at the 5.0 migration guide?
> http://trac.osgeo.org/mapserver/browser/tags/rel-5-0-0/mapserver/MIGRATION_GUIDE.TXT
> If not, take a look at the section titled, 'URL configuration changes'. I
> don't know for sure, but you might want to try something like
> map.resolution=25
> David.
> -----Original Message-----
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Bart van den Eijnden
> *Sent:* Friday, January 18, 2008 6:03 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] map_resolution in 5.0 does not work
> Hi list,
> why does the following fail against Mapserver 5.0, it used to work in
> previous version:
> map_resolution=25, for instance:
> http://test.intranet.rijkswaterstaat.nl/services/geoservices/basispakket/dtb?map_resolution=25&LAYERS=AAA161&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&STYLES=default&HEIGHT=1260&VERSION=1.1.1&SRS=EPSG:28992&WIDTH=1530&BBOX=%2D64210%2E0044897549%2C273591%2E761008437%2C364210%2E004489755%2C626408%2E238991563&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
> Mapserver 5.0 returns:
> getDouble(): Symbol definition error. Parsing error near (25):(line 1)
> TIA.
> Best regards,
> Bart
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080118/12cf622f/attachment.html
