map_resolution in 5.0 does not work
Bart van den Eijnden
bartvde at GMAIL.COM
Fri Jan 18 07:11:38 PST 2008
Hi David,
the GET calls works if I remove the parameter, so the MAP file works fine.
If I change 25 in 50, I see 50 in Mapserver's error message, so I am 99,9%
sure it is causing this error.
Resolution is a double, in my OGC map files I always use 90.71.
Even in a normal mode=map, Mapserver complains about the parameter.
Best regards,
Bart
On Jan 18, 2008 4:02 PM, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> Bart,
> Apologies. I didn't notice that it was you who had posted the question.
> Usually, if I see that you have pointed out an issue, I assume that it is a
> real bug right away!
> A couple of thoughts:
> Does the GET call work if you just remove 'map_resolution=25' from your
> URL?
> The error references a 'symbol definition error' near line 25, are you
> sure that there isn't a syntax error in the map file?
> the get_double() error sounds funny because the resolution value is
> supposed to be an int.
> Is this just a problem with the WMS request, can you get this resolution
> substitution call to work as a mode=map request?
> David.
> -----Original Message-----
> *From:* Bart van den Eijnden [mailto:bartvde at gmail.com]
> *Sent:* Friday, January 18, 2008 8:44 AM
> *To:* Fawcett, David
> *Cc:* MAPSERVER-USERS at lists.umn.edu
> *Subject:* Re: [UMN_MAPSERVER-USERS] map_resolution in 5.0 does not work
> Hi David,
> I did read it, but could not really find a clue in it for my problem.
> Are the . not typos? There are also _ examples still in there.
> Anyways, I tried map.resolution=25 to no avail.
> Best regards,
> Bart
> On Jan 18, 2008 2:59 PM, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> > Have you looked at the 5.0 migration guide? http://trac.osgeo.org/mapserver/browser/tags/rel-5-0-0/mapserver/MIGRATION_GUIDE.TXT
> > If not, take a look at the section titled, 'URL configuration changes'.
> > I don't know for sure, but you might want to try something like
> > map.resolution=25
> > David.
> > *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> > *On Behalf Of *Bart van den Eijnden
> > *Sent:* Friday, January 18, 2008 6:03 AM
> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Subject:* [UMN_MAPSERVER-USERS] map_resolution in 5.0 does not work
> > Hi list,
> > why does the following fail against Mapserver 5.0, it used to work in
> > previous version:
> > map_resolution=25, for instance:
> > http://test.intranet.rijkswaterstaat.nl/services/geoservices/basispakket/dtb?map_resolution=25&LAYERS=AAA161&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&STYLES=default&HEIGHT=1260&VERSION=1.1.1&SRS=EPSG:28992&WIDTH=1530&BBOX=%2D64210%2E0044897549%2C273591%2E761008437%2C364210%2E004489755%2C626408%2E238991563&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
> > Mapserver 5.0 returns:
> > getDouble(): Symbol definition error. Parsing error near (25):(line 1)
> > TIA.
> > Best regards,
> > Bart
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080118/2cae19b9/attachment.htm>
More information about the MapServer-users
