Sure I can. In fact, got some results at hand.
Attached is a "tail-ed" output from the last 150 lines of the log
when it crashed, for comparison values. You get to see for the first
page or so it processing the data during a zoom in, then you see a bit
of java debug native to the application on the last few lines and when a
zoom out occurs all goes down.
What I've found interesting in that last line just before the app
going tits up is the awfully high offset value. I don't have a clue what
that value stands for, but it seems out of place comparing with the
others. That layer in question is one being indexed by a tileindex, and
it was split from a larger shapefile using OpenJump.
Also may be worth noting that I was having problems to get it to
crash with the patch. I was suspecting of a race condition being slowed
down by the extra work it had writing the ouput to file, so I asked a
colleague to log on and give it at go simultaneously, and that did it.
It went down in 30 secs with us both just grinding the zoom button (not
before spewing 220 megs of logs :)
I hope it helps.
Log attached. Thanks a lot,
Rodrigo
ps: re-sending with a smaller chunk of the log file. Previous one
returned because the file was too big. Oops ;)
Umberto Nicoletti wrote:
> Rodrigo, could you apply the attached patch and the post the last
> output of the application before the segfault?
> Please note that it will log an awful LOT of stuff!
> Regards,
> Umberto
> On Jan 18, 2008 2:07 PM, Rodrigo Del C. Andrade
> <rodrigo.andrade at digitro.com.br> wrote:
>> Good morning all.
>> I am running tests on Mapserver 5 to test its viability on our
>> production enviroment and I have run into some problems I am having
>> trouble to figure out.
>> A little background, may be irrelevant, but could be useful, idk:
>> - We have a stand alone java server application (doing the map work
>> with Java Mapscript) which talks via RMI with the client part of the
>> app, which is running on Tomcat. We've done it this way because past
>> crashes on mapserver used to bring Tomcat down with it
>> - This mapscript binary was compiled with all the latest stable
>> versions of GDAL, GEOS, Proj, AGG, LibPNG, GD and Freetype.
>> - We are outputting the final map images with AGG.
>> - The source data lives in Shape files. All of them have indexes,
>> and I broke large areas into smaller chunks and tile indexed them with
>> tile4ms.
>> Now, this one is the first of the the 2 different segfaults I am
>> experiencing with 5.0, but decided to focus on this one first because it
>> seems to happen more frequently. Whenever I am zooming in or out in the
>> map, this bugger seems to happen at random. I was'nt able to pin point a
>> pattern for it to happen, looks like just using it long enough will do it.
>> # An unexpected error has been detected by HotSpot Virtual Machine:
>> # SIGSEGV (0xb) at pc=0x00734600, pid=30922, tid=1812704176
>> # Java VM: Java HotSpot(TM) Server VM (1.5.0_07-b03 mixed mode)
>> # Problematic frame:
>> # C [libc.so.6+0x69600] strncpy+0x30
>> I am not any C buff by any means, but judging from a strncpy error,
>> I assume something in the way strings are created/handled might have
>> changed since 4.x (I haven't been following the list recently, forgive
>> me if it's old news)
>> Any ideas about what might be causing it?
>> -- Full log is bellow the sig.
>> Thanks!
>> *Rodrigo Del C. Andrade*
>> /Programador/
>> /SIC - SSE - Soluções Segurança Pública/
>> *DÍGITRO TECNOLOGIA*
>> *E-mail:* rodrigo.andrade at digitro.com.br
>> <mailto:rodrigo.andrade at digitro.com.br>
>> *Fone:* +55 48 3281-7314 / +55 48 3281-7000
>> *Fax:* +55 48 3281-7299
>> *Site:* www.digitro.com <http://www.digitro.com
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 69.50011 0999999999999999431870000000623999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 171.50003 0999999999999999431870000000709999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SAO JOSE SAO JOSE 0 0 0 0 111.51591 0999999999999999431870000004480999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 306.91488 0999999999999999431870000001895999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 1020.37747 0999999999999999431870000001667999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CAMPINA CAMPINA 0 0 0 0 45.04036 0999999999999999431870000001899999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CAMPINA CAMPINA 0 0 0 0 67.05388 0999999999999999431870000001952999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CAMPINA CAMPINA 0 0 0 0 37.54842 0999999999999999431870000001995999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME JARDIM AMERICA JARDIM AMERICA 0 0 0 0 41.92209 0999999999999999431870000005364999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CENTRO CENTRO 0 0 0 0 79.03094 0999999999999999431870000003207999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 195.26519 0999999999999999431870000005074999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 28.20357 0999999999999999431870000005087999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 82.45957 0999999999999999431870000005160999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 73.86569 0999999999999999431870000005088999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 103.91749 0999999999999999431870000005161999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 291.05865 0999999999999999431870000005451999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME JARDIM AMERICA JARDIM AMERICA 0 0 0 0 74.98089 0999999999999999431870000006231999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME JARDIM AMERICA JARDIM AMERICA 0 0 0 0 67.61865 0999999999999999431870000006546999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 446.02951 0999999999999999431870000001622999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME JARDIM AMERICA JARDIM AMERICA 0 0 0 0 108.00007 0999999999999999431870000006633999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 71.78734 0999999999999999431870000006207999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 157.31347 0999999999999999431870000006063999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 65.57010 0999999999999999431870000006109999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 137.79423 0999999999999999431870000006062999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 95.56845 0999999999999999431870000006313999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 116.81671 0999999999999999431870000006514999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 989.77578 0999999999999999431870000003828999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 391.15175 0999999999999999431870000004203999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 116.23582 0999999999999999431870000004296999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 186.74663 0999999999999999431870000004486999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 322.44457 0999999999999999431870000004853999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 2028.55315 0999999999999999431870000006341999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 141.37846 0999999999999999431870000006405999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 568.69302 0999999999999999431870000006481999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 69.31250 0999999999999999431870000005455999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CENTRO CENTRO 0 0 0 0 92.67774 0999999999999999431870000004261999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 204.02756 0999999999999999431870000001930999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 175.02310 0999999999999999431870000002093999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 201.42736 0999999999999999431870000002056999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 1225.70711 0999999999999999431870000002108999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SAO MIGUEL SAO MIGUEL 0 0 0 0 146.76533 0999999999999999431870000003732999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SAO MIGUEL SAO MIGUEL 0 0 0 0 118.98536 0999999999999999431870000003862999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SAO MIGUEL SAO MIGUEL 0 0 0 0 230.32927 0999999999999999431870000003987999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 142.44898 0999999999999999431870000005848999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 139.62450 0999999999999999431870000005969999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME MORRO DO ESPELHO MORRO DO ESPELHO 0 0 0 0 75.96052 0999999999999999431870000006029999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 82.26161 0999999999999999431870000006410999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 200.57715 0999999999999999431870000001351999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 34.82097 0999999999999999431870000006945999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 49.47036 0999999999999999431870000006963999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 45.27202 0999999999999999431870000006968999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 18.54642 0999999999999999431870000006974999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 39.76868 0999999999999999431870000006904999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 27.56703 0999999999999999431870000006918999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 63.95616 0999999999999999431870000005005999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 83.00401 0999999999999999431870000004968999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 46.50340 0999999999999999431870000006383999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 47.48274 0999999999999999431870000006397999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CRISTO REI CRISTO REI 0 0 0 0 42.39993 0999999999999999431870000005511999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME PADRE REUS PADRE REUS 0 0 0 0 85.01112 0999999999999999431870000006348999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 44.30709 0999999999999999431870000004573999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 16.42648 0999999999999999431870000004574999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 51.87741 0999999999999999431870000004646999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME PADRE REUS PADRE REUS 0 0 0 0 70.77021 0999999999999999431870000006206999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 62.76942 0999999999999999431870000004894999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 71.27721 0999999999999999431870000006507999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 317.63531 0999999999999999431870000006560999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 61.53715 0999999999999999431870000006922999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 47.18580 0999999999999999431870000006580999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 68.28452 0999999999999999431870000006736999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SANTA TERESA SANTA TERESA 0 0 0 0 88.21091 0999999999999999431870000006758999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 74.57641 0999999999999999431870000004375999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 43.48645 0999999999999999431870000004586999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 58.64646 0999999999999999431870000004545999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 80.01382 0999999999999999431870000004503999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 69.80867 0999999999999999431870000004461999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 45.16793 0999999999999999431870000004402999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME DUQUE DE CAXIAS DUQUE DE CAXIAS 0 0 0 0 172.51387 0999999999999999431870000006835999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CRISTO REI CRISTO REI 0 0 0 0 175.13757 0999999999999999431870000006304999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CRISTO REI CRISTO REI 0 0 0 0 24.15576 0999999999999999431870000006310999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CRISTO REI CRISTO REI 0 0 0 0 44.28336 0999999999999999431870000006305999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CRISTO REI CRISTO REI 0 0 0 0 46.13712 0999999999999999431870000006254999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME CRISTO REI CRISTO REI 0 0 0 0 74.79817 0999999999999999431870000006478999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 278.29627 0999999999999999431870000005684999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 173.59253 0999999999999999431870000005685999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 285.43212 0999999999999999431870000005728999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 84.17847 0999999999999999431870000005534999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 91.31890 0999999999999999431870000005533999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME ARROIO DA MANTEIGA ARROIO DA MANTEIGA 0 0 0 0 78.44769 0999999999999999431870000005454999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 297.30867 0999999999999999431870000005589999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 81.83300 0999999999999999431870000005486999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 162.67142 0999999999999999431870000005487999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 76.87906 0999999999999999431870000005688999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 90.44888 0999999999999999431870000005689999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 76.77067 0999999999999999431870000005375999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 113.76227 0999999999999999431870000005376999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 410.00976 0999999999999999431870000005586999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 56.38266 0999999999999999431870000005620999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 87.55316 0999999999999999431870000005609999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 60.76570 0999999999999999431870000005677999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 569.92198 0999999999999999431870000006089999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 23.19963 0999999999999999431870000005670999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 43.58246 0999999999999999431870000005700999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 101.03248 0999999999999999431870000005650999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 71.22247 0999999999999999431870000005651999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 214.97166 0999999999999999431870000005587999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 75.02672 0999999999999999431870000005462999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 168.84227 0999999999999999431870000005419999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 400.42763 0999999999999999431870000005418999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME VICENTINA VICENTINA 0 0 0 0 627.11311 0999999999999999431870000006440999999999999999,length=15)
strncpy(offset=48,record= RSSAO LEOPOLDO SEM NOME SAO JOAO BATISTA SAO JOAO BATISTA 0 0 0 0 154.97158 0999999999999999431870000006734999999999999999,length=15)
strncpy(offset=1,record= ./gravatai/gravatai_rs /hom,length=255)
strncpy(offset=48,record= RSGRAVATAI ESTRADA SANTA TECLA AGUAS MORTAS AGUAS MORTAS 9410061094100610 1 1169 0 1168 1184.20478 0430920000000074430920000000005430920000000074,length=15)
strncpy(offset=48,record= RSGRAVATAI ESTRADA SANTA TECLA AGUAS MORTAS AGUAS MORTAS 9410061094100610 1169 1242 1168 1241 73.58501 0430920000000074430920000000007430920000000074,length=15)
strncpy(offset=48,record= RSGRAVATAI ESTRADA SANTA TECLA AGUAS MORTAS AGUAS MORTAS 9410061094100610 1242 2547 1241 2546 1322.53009 0430920000000074430920000000013430920000000074,length=15)
strncpy(offset=48,record= RSGRAVATAI SEM NOME NEOPOLIS NEOPOLIS 0 0 0 0 405.49499 0999999999999999430920000000001999999999999999,length=15)
strncpy(offset=48,record= RSGRAVATAI SEM NOME NEOPOLIS NEOPOLIS 0 0 0 0 2852.65934 0999999999999999430920000000004999999999999999,length=15)
strncpy(offset=48,record= RSGRAVATAI SEM NOME NEOPOLIS NEOPOLIS 0 0 0 0 3013.33244 0999999999999999430920000000014999999999999999,length=15)
strncpy(offset=48,record= RSGRAVATAI SEM NOME NEOPOLIS NEOPOLIS 0 0 0 0 638.82982 0999999999999999430920000000006999999999999999,length=15)
strncpy(offset=48,record= RSGRAVATAI SEM NOME NEOPOLIS NEOPOLIS 0 0 0 0 2345.79413 0999999999999999430920000000008999999999999999,length=15)
strncpy(offset=48,record= RSGRAVATAI SEM NOME NEOPOLIS NEOPOLIS 0 0 0 0 1414.06046 0999999999999999430920000000010999999999999999,length=15)
strncpy(offset=1,record= hidrografia/hidrografia_17 9999,length=255)
strncpy(offset=1,record= hidrografia/hidrografia_3 9999,length=255)
strncpy(offset=99,record= 109688000.0000000000000000 595448.0000000000000000 0 0 ,length=50)
14:23:43,939 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:1077 () - Salvando imagem: /home2/java/tomcat8040/temp/mapa26102.gif
14:23:43,973 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:447 () - Mapa renderizado: 584ms
14:23:43,974 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:449 () - Extents final: { 'minx': -51.25389628689 , 'miny': -29.83654653269458 , 'maxx': -51.03540387753817 , 'maxy': -29.70754003259925 }
14:23:45,105 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:510 () - Extents inicial:{ 'minx': -51.25389628689 , 'miny': -29.83654653269458 , 'maxx': -51.03540387753817 , 'maxy': -29.70754003259925 }
14:23:45,105 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:515 () - opcao:zoomOut
14:23:45,105 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:537 () - panner/zoomIn/zoomOut
14:23:45,106 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:569 () - Ocultando/Exibindo rótulos...
14:23:45,106 DEBUG [168.167.93] gis.model.IDSegGisMapFactory:439 () - Desenhando mapa...
strncpy(offset=1,record= ./limites_estaduais/limites_13 ,length=255)
strncpy(offset=1,record= ./limites_estaduais/limites_10 ,length=255)
strncpy(offset=106926,record=,length=18761)
# SIGSEGV (0xb) at pc=0x00734600, pid=12214, tid=1816411056
# An error report file with more information is saved as hs_err_pid12214.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
