map_resolution in 5.0 does not work
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Sun Jan 20 11:16:44 EST 2008
This has been fixed in 5.0.1 and the main trunk. A missing call to the lexer that set
tokenizing state was the culprit.
Steve
>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 01/18/08 5:49 PM >>>
This is a different problem. The variable is exposed. It's a problem in mapfile.c that needs
fixing. I'll file a bug and target 5.0.1 which should be on track for early next week.
Steve
>>> On 1/18/2008 at 9:19 AM, in message
<47906F060200008F000139F3 at co5.dnr.state.mn.us>, Steve Lime
<Steve.Lime at DNR.STATE.MN.US> wrote:
> It's possible it wasn't exposed. I'll check and fix in 5.0.1 and 5.2...
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-259-5473
>>>> Bart van den Eijnden <bartvde at GMAIL.COM> 01/18/08 9:11 AM >>>
> Hi David,
> the GET calls works if I remove the parameter, so the MAP file works fine.
> If I change 25 in 50, I see 50 in Mapserver's error message, so I am 99,9%
> sure it is causing this error.
> Resolution is a double, in my OGC map files I always use 90.71.
> Even in a normal mode=map, Mapserver complains about the parameter.
> Best regards,
> Bart
> On Jan 18, 2008 4:02 PM, Fawcett, David <David.Fawcett at state.mn.us> wrote:
>> Bart,
>> Apologies. I didn't notice that it was you who had posted the question.
>> Usually, if I see that you have pointed out an issue, I assume that it is a
>> real bug right away!
>> A couple of thoughts:
>> Does the GET call work if you just remove 'map_resolution=25' from your
>> URL?
>> The error references a 'symbol definition error' near line 25, are you
>> sure that there isn't a syntax error in the map file?
>> the get_double() error sounds funny because the resolution value is
>> supposed to be an int.
>> Is this just a problem with the WMS request, can you get this resolution
>> substitution call to work as a mode=map request?
>> David.
>> -----Original Message-----
>> *From:* Bart van den Eijnden [mailto:bartvde at gmail.com]
>> *Sent:* Friday, January 18, 2008 8:44 AM
>> *To:* Fawcett, David
>> *Cc:* MAPSERVER-USERS at lists.umn.edu
>> *Subject:* Re: [UMN_MAPSERVER-USERS] map_resolution in 5.0 does not work
>> Hi David,
>> I did read it, but could not really find a clue in it for my problem.
>> Are the . not typos? There are also _ examples still in there.
>> Anyways, I tried map.resolution=25 to no avail.
>> Best regards,
>> Bart
>> On Jan 18, 2008 2:59 PM, Fawcett, David <David.Fawcett at state.mn.us> wrote:
>> > Have you looked at the 5.0 migration guide?
> http://trac.osgeo.org/mapserver/browser/tags/rel-5-0-0/mapserver/MIGRATION_GUIDE
> .TXT
>> > If not, take a look at the section titled, 'URL configuration changes'.
>> > I don't know for sure, but you might want to try something like
>> > map.resolution=25
>> > David.
>> > *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>> > *On Behalf Of *Bart van den Eijnden
>> > *Sent:* Friday, January 18, 2008 6:03 AM
>> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
>> > *Subject:* [UMN_MAPSERVER-USERS] map_resolution in 5.0 does not work
>> > Hi list,
>> > why does the following fail against Mapserver 5.0, it used to work in
>> > previous version:
>> > map_resolution=25, for instance:
> http://test.intranet.rijkswaterstaat.nl/services/geoservices/basispakket/dtb?
> map_resolution=25&LAYERS=AAA161&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&STYL
> ES=default&HEIGHT=1260&VERSION=1.1.1&SRS=EPSG:28992&WIDTH=1530&BBOX=%2D64210%2E004
> 4897549%2C273591%2E761008437%2C364210%2E004489755%2C626408%2E238991563&TRANSPA
> RENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
>> > Mapserver 5.0 returns:
>> > getDouble(): Symbol definition error. Parsing error near (25):(line 1)
>> > TIA.
>> > Best regards,
>> > Bart
