TYPE truetype
The Bun rosario.carbone at IPL.COM
Mon Jan 21 11:52:27 EST 2008
Hi list,
I am having problems with the labels: Text with the following configuration
is showed correctly but not orientated with streets and buildings, it is all
orizzontal. As far as I know the only type you can define an angle
(orientation) should be the TRUETYPE, well if I uncomment the line with TYPE
truetype then  my map is not displayed at all, the weird thing is I cannot
find any message in the error log of Apache, surely I am missing something.
Here you are the LAYER portion:
LAYER
  NAME cartotext
  TYPE POINT
  STATUS DEFAULT
  LABELCACHE ON
  LABELITEM "textstring"
  DEBUG ON
  CONNECTIONTYPE OGR
  CONNECTION
"MySQL:test,user=root,host=localhost,password=password,port=3306"
  DATA "mm_cartographictext_topo"
  CLASS
    STYLE # It is actually the point
      COLOR 255 0 0
      ANTIALIAS TRUE
    END
    LABEL # Is the text
      ANGLE AUTO
      COLOR 0 153 0
      #TYPE truetype
      FONT "arial-bold"
      POSITION AUTO
      BUFFER 4
      ANTIALIAS TRUE
      PARTIALS FALSE
    END # end of label
  END
END
I hope someone can help I have tried at least 50 different configuration and
noone works.
Regards
Rosario
View this message in context: http://www.nabble.com/TYPE-truetype-tp15001513p15001513.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
