Map file with 35,000+ Lines... management issue
riteshambastha ritesh.linux at GMAIL.COM
Thu Jan 24 10:16:02 EST 2008
Dear Stephen,
The number of layers exceeded much because I am including each individual
shapefile multiple times for different Maxcale/Minscale values.  So, a
shapefile is now called by 3-4 layers, each layer having different
Maxscale/Minscale values.
I hope I made my point clear.
Regards,
Ritz
Stephen Woodbridge wrote:
> Ok, I need to ask the obvious question, WHY? do you feel you need 658
> layers. Is this because you have lots of shapefiles? and most of the
> layer definitions are the same except for the data source?
> For Tiger data I have 33000 shapefiles, but I only have about 20+-
> layers. Are you using tileindexes? Do you know what they are? Just
> trying to diagnose your situation a little better so we can help.
> -Steve W
> ritesh ambastha wrote:
>> Thanks Bob,
>> The map file consists of 658 Layers.
>> It runs with openlayers and postgis.
>> Now, am trying to sort out the best way for solving this issue.
>> Your reply helped me to view at the problems+solutions in broad
>> spectrum..
>> Warm Regards,
>> Ritesh
>> On Jan 24, 2008 1:04 AM, Bob Basques <Bob.Basques at ci.stpaul.mn.us> wrote:
>>> Ritz,
>>> Whew, 35k lines, that big.  How many layers is that anyway?   The
>>> Googlish
>>> mapfile I just did only has 1100 lines in it, and that's mostly for
>>> readability.  I could probably get it down to half that size if I tried.
>>> Don't know what I can contribute as a "Best Practice", because I feel
>>> that
>>> in most cases, that form follows function, if you need a capability, you
>>> build it.  Anyway, here are some of my thoughts.
>>> These same sorts of performance questions crossed my mind too.  The
>>> Googlish
>>> mapfile I've been working on has 72 separate STYLE definitions for
>>> example.
>>> Mostly ranged around threshholding of certain styles.  I can see that
>>> adding
>>> in the Water bodies, Railroad, Parks, and such, is really going to make
>>> this
>>> thing big.  I may just do those as separate MapFiles though since
>>> GeoMoose
>>> handles things like these separations very nicely.
>>> These are some of the primary reasons that contributed to the way we've
>>> built GeoMoose as a client and why it runs against MapServer CGI, so
>>> that it
>>> can abstract the layer calls in this fashion.  We're running 135+ layers
>>> internally at the moment, and they all have their own MAPFILE and are
>>> all
>>> called separately from the client.  It has made life much easier with
>>> regard
>>> to MapFile creation and maintenance, since each data custodian handles
>>> their
>>> respective MAPFILE.  The performance issues are minimized well since
>>> even
>>> the data intensive layers are not too bad from a performance standpoint.
>>> But even my Googlish looking mapfile got prettty big (in my opinion) for
>>> simply displaying centerlines of streets.   I've learned quite a bit
>>> from
>>> these exercises about these types of questions.  While I have yet to
>>> attack
>>> the performance side of things, I anticpate that I'll need to segregate
>>> the
>>> data out at differing thresholds in order to gain some performance
>>> boots.
>>> We're all about doing dynamic requests here since many of our datasets
>>> change very frequently, in some cases, down to the minute.  I may look
>>> into
>>> tiling at some point in the future, but it will still be only for some
>>> of
>>> the layers, there will still be a need to have this dynamic request
>>> structure in place.
>>> bobb
>>> Bob Basques
>>> GIS Systems Developer
>>> City of Saint Paul, MN
>>> GISmo
>>> Powered by
>>> GeoMOOSE
>>>>>> riteshambastha <ritesh.linux at GMAIL.COM> wrote:
>>> Dear Readers,
>>> I have developed a map file with more than 35,000 Lines. Its size will
>>> grow
>>> by double/triple in next few months. Now, I am trying to tune my map
>>> file by
>>> removing unwanted lines. Still, I am bit confused about its maintenance.
>>> Please throw some lights over writing map files by following best
>>> practices.
>>> Thanks in advance.
>>> Regards,
>>> Ritz
>>> View this message in context:
>>> http://www.nabble.com/Map-file-with-35,000+-Lines...-management-issue-tp15048892p15048892.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Map-file-with-35%2C000%2B-Lines...-management-issue-tp15048892p15065742.html
