problem compiling 5.0.1
Daniel Morissette dmorissette at MAPGEARS.COM
Fri Jan 25 10:26:43 EST 2008
frequens wrote:
> Actually the fix works also with flex 2.5.4a....
> Both machines up and running, correctly at a first glance...
Thanks for confirming the fix.
FYI, the reason why that works on both of your systems is that flex is
not used any more once you use the updated file (the new maplexer.c is
more recent than maplexer.l so the Makefile does not try to call flex to
generate maplexer.c any more).
Daniel
Daniel Morissette
http://www.mapgears.com/
