[gdal-dev] mapinfo to postgis problem
FX GAMOY fx.gamoy at GEOMATIKA.FR
Mon Jan 28 08:13:02 EST 2008
Hello Tamas,
i ve made two screenshots
the first one image_reseau_test_sens.png has been made using mapinfo. (initial
data)
the mapinfo tab has been translated into postgis using ogr2ogr..
The second one (sens_mapserver.png) is computed by mapserver.
look a the red network. You can notice that somtimes the arrows in the two
screenshots are not computed on the same way.
Thanks
fx
Le Tuesday 22 January 2008 11:00:26 Tamas Szekeres, vous avez écrit :
> 2008/1/22, FX GAMOY <fx.gamoy at geomatika.fr>:
> > i work with polylines representing a water network ( system )..
> > i would like to draw on the map the way the line has been vectorized with
> > mapinfo.. using some arrows
> > But this way seem to be sometimes changed by the ogr2ogr translation or
> > by mapserver when computing the map.
> Could you describe the behaviour of the change?
> Best regards,
> Tamas
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080128/b3045eae/image_reseau_test_sens.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080128/b3045eae/sens_mapserver.png
