mapserver doesnt't see libgdal
Peter Loewe
peter.loewe at GMX.DE
Mon Jan 28 09:33:03 EST 2008
I am trying to compile MS from the 5.0.1 source on a remote (webhosting) system (i have no root priviliges there).
For some unknown reason, mapserver refuses to acknowledge the location of libgdal [GDAL itself was built from the sources (1.5.0) and shows no problems]:
---MS-Configure:
LDFLAGS='-L/home/pacs/aho02/users/loewe01/homemade/lib -L/lib -L/usr/lib -L/usr/local/lib -L/usr/X11R6/lib -Wl,-rpath=/home/pacs/xxx/homemade/lib' \
./configure \
--prefix=/home/pacs/xxx/homemade/lib \
--enable-runpath \
--with-gd=/home/pacs/xxx/homebuilt/gd-2.0.33 \
--with-proj \
--with-gdal=/home/pacs/xxx/homemade/bin/gdal-config \
--without-ogr \
--without-wcs \
--with-wmsclient \
--with-wms \
--without-wfs \
--without-wfsclient \
--with-xml2-config=/usr/bin/xml2-config \
--without-sos \
--with-pdf=/home/pacs/xxx/homebuilt/PDFlib-6.0.3p5-Linux/bind/c \
--with-php=/usr/local/share/php/5.1.1
MS compiles nicely.
Unfortunately, this is what ldd mapserv has to tell:
ldd mapserv
linux-gate.so.1 => (0xb7f68000)
libgd.so.2 => /home/pacs/xxx/homebuilt/gd-2.0.33/.libs/libgd.so.2 (0xb7f17000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb7eeb000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7e81000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb7e5e000)
libz.so.1 => /usr/lib/libz.so.1 (0xb7e4a000)
libXpm.so.4 => /usr/lib/libXpm.so.4 (0xb7e3a000)
libX11.so.6 => /usr/lib/libX11.so.6 (0xb7d4e000)
libproj.so.0 => /usr/lib/libproj.so.0 (0xb7d18000)
libgdal.so.1 => not found
Yet, libgdal.so.1 _does_ exist:
ls -l ~/homemade/lib/
-rw-r--r-- 1 libgdal.a
-rwxr-xr-x 1 libgdal.la
lrwxrwxrwx 1 libgdal.so -> libgdal.so.1.12.0
lrwxrwxrwx 1 libgdal.so.1 -> libgdal.so.1.12.0
-rwxr-xr-x 1 libgdal.so.1.12.0
-rw-r--r-- 1 libpdf.a
Has anybody encountered this before ?
ANY suggestion would be much appreciated!
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
