mapserver doesnt't see libgdal
"Peter Löwe"
peter.loewe at GMX.DE
Mon Jan 28 09:54:06 EST 2008
Guillaume,
thanks for the hint, but I have no root-priviliges.
Cheers,
Peter
-------- Original-Nachricht --------
> Datum: Mon, 28 Jan 2008 15:36:20 +0100
> Von: Guillaume Sueur <guillaume.sueur at neogeo-online.net>
> An: peter.loewe at GMX.DE, MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] mapserver doesnt\'t see libgdal
> just a clue :
> add your ~/homemade/lib/ to /etc/ld.so.conf and run ldconfig as root
> Guillaume
> Peter Loewe a écrit :
> > Hi,
> > I am trying to compile MS from the 5.0.1 source on a remote (webhosting)
> system (i have no root priviliges there).
> > For some unknown reason, mapserver refuses to acknowledge the location
> of libgdal [GDAL itself was built from the sources (1.5.0) and shows no
> problems]:
> > ---MS-Configure:
> > LDFLAGS='-L/home/pacs/aho02/users/loewe01/homemade/lib -L/lib -L/usr/lib
> -L/usr/local/lib -L/usr/X11R6/lib -Wl,-rpath=/home/pacs/xxx/homemade/lib'
> > ./configure \
> > --prefix=/home/pacs/xxx/homemade/lib \
> > --enable-runpath \
> > --with-gd=/home/pacs/xxx/homebuilt/gd-2.0.33 \
> > --with-proj \
> > --with-gdal=/home/pacs/xxx/homemade/bin/gdal-config \
> > --without-ogr \
> > --without-wcs \
> > --with-wmsclient \
> > --with-wms \
> > --without-wfs \
> > --without-wfsclient \
> > --with-xml2-config=/usr/bin/xml2-config \
> > --without-sos \
> > --with-pdf=/home/pacs/xxx/homebuilt/PDFlib-6.0.3p5-Linux/bind/c \
> > --with-php=/usr/local/share/php/5.1.1
> > MS compiles nicely.
> > Unfortunately, this is what ldd mapserv has to tell:
> > ldd mapserv
> > linux-gate.so.1 => (0xb7f68000)
> > libgd.so.2 =>
> /home/pacs/xxx/homebuilt/gd-2.0.33/.libs/libgd.so.2 (0xb7f17000)
> > libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb7eeb000)
> > libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7e81000)
> > libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb7e5e000)
> > libz.so.1 => /usr/lib/libz.so.1 (0xb7e4a000)
> > libXpm.so.4 => /usr/lib/libXpm.so.4 (0xb7e3a000)
> > libX11.so.6 => /usr/lib/libX11.so.6 (0xb7d4e000)
> > libproj.so.0 => /usr/lib/libproj.so.0 (0xb7d18000)
> > libgdal.so.1 => not found
> > Yet, libgdal.so.1 _does_ exist:
> > ls -l ~/homemade/lib/
> > -rw-r--r-- 1 libgdal.a
> > -rwxr-xr-x 1 libgdal.la
> > lrwxrwxrwx 1 libgdal.so -> libgdal.so.1.12.0
> > lrwxrwxrwx 1 libgdal.so.1 -> libgdal.so.1.12.0
> > -rwxr-xr-x 1 libgdal.so.1.12.0
> > -rw-r--r-- 1 libpdf.a
> > Has anybody encountered this before ?
> > ANY suggestion would be much appreciated!
> > Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS.
Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail
