msDrawMap(): Image handling error
Paul Alarcon
paul_pag00 at HOTMAIL.COM
Mon Jan 28 12:48:08 EST 2008
Hello everyone I´m using a html template to make search in mapserver, the problem is that I change the table from one of the shapes and now I have this error"msDrawMap(): Image handling error. Failed to draw layer named 'Escuelas'." when I make a query a dont tell me nothing more, i used other table for "Escuelas" and it work but with this one dont work
I used this one for display information and it works. but for query i have that error
Here is the map file
Help me please
MAP
NAME test #MapFile testing possible bug on itemquery
STATUS ON
SIZE 800 600
EXTENT 836705.704288 9999113.003817 1143436.012879 10051849.051893
STATUS ON
#SHAPEPATH "/home/mapdata/Pichincha/pruebas/POLITICO 2002/"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
FONTSET "/srv/www/htdocs/ka-map/fontset.txt"
WEB
HEADER "/srv/www/htdocs/headersuc.html"
FOOTER "/srv/www/htdocs/footersuc.html"
IMAGEPATH "/srv/www/htdocs/temp/"
IMAGEURL "/temp/"
TEMPLATE "somthing.html"
EMPTY "/emptysuc.html"
LOG "/srv/www/htdocs/temp/sucumbios"
END # End of Web Interface
# Reference map######################
REFERENCE
STATUS ON
IMAGE "/srv/www/htdocs/php_test/provincias/sucumbios/sucumbios_base.gif"
SIZE 200 198
EXTENT 835105.70 9949113.00 1145436.01 10071849.05
COLOR -1 -1 -1
OUTLINECOLOR 255 0 100
MINBOXSIZE 3
MAXBOXSIZE 0
MARKER 0
MARKERSIZE 0
END
#Legend
LEGEND
STATUS on
#IMAGECOLOR 65 171 49
POSITION LL
LABEL
TYPE truetype
FONT "blbi____"
COLOR 0 0 0
SIZE 10
ANTIALIAS true
END
END
# Symbol para lineas gruesas
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol para puntos
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
#Symbol cuadrado base
SYMBOL
NAME "Cuadro"
TYPE VECTOR
POINTS
0 0
0 1
1 1
1 0
0 0
END
FILLED TRUE
END
#SYMBOL circulo
SYMBOL
NAME "punkt"
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
querymap
status on
SIZE 700 500
style SELECTED
END
LAYER
NAME cantones
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "host=localhost port=5432 dbname=demo_postgis user=postgres password="
DATA "the_geom from cantones"
LABELCACHE on
TOLERANCE 0
METADATA
qstring_validation_pattern '.'
END
LABELITEM "non_canton"
CLASS
TEMPLATE "/srv/www/htdocs/querytemplate2.html"
NAME "Canton"
OUTLINECOLOR 0 0 0
COLOR 187 212 201
END
END #end layer
LAYER
NAME parroquias
STATUS DEFAULT
TYPE polygon
DATA "the_geom from parroquias"
STATUS default
METADATA
END
LABELITEM "parroquia"
#DATA 'parroquial'
TOLERANCE 0
CLASS
NAME "Parroquia"
TEMPLATE "/srv/www/htdocs/querytemplate3.html"
OUTLINECOLOR 100 0 0
COLOR -1 -1 -1
END
END #end layer
LAYER
NAME PROVINCIAS
STATUS DEFAULT
TYPE line
#METADATA
# qstring_validation_pattern '.'
#END
#LABELITEM "PARROQUIA"
#DATA 'provincial'
DATA "the_geom from provincial"
CLASS
NAME "Provincia"
#OUTLINECOLOR 100 0 0
COLOR 0 0 5
STYLE
SYMBOL "BigLine"
SIZE 4
#COLOR 50 212 51
OUTLINECOLOR 12 0 0
END
END
END #end layer
LAYER
NAME "Escuelas"
DATA "the_geom from gis_plantel"
STATUS default
TYPE point
#LABELITEM "plan_nombre"
LABELCACHE on
TOLERANCE 0
HEADER "/srv/www/htdocs/head_plan.html"
FOOTER "/srv/www/htdocs/foot_plan.html"
CLASSITEM "pla_nivel"
METADATA
END
DEBUG on
GROUP "PLANTELES"
CLASS
NAME "PREPRIMARIO"
TEMPLATE "/srv/www/htdocs/querytemplate.html"
EXPRESSION "PREPRIMARIO"
STYLE
END
STYLE
SYMBOL "punkt"
SIZE 6
COLOR 204 204 0
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
#BACKGROUNDCOLOR 255 255 255
MINDISTANCE 20
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END #label
END #clase
CLASS
NAME "PRIMARIO"
EXPRESSION "PRIMARIO"
STYLE
END
STYLE
SYMBOL "punkt"
SIZE 6
COLOR 142 94 94
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
MINDISTANCE 20
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END #label
END # Clase
CLASS
NAME "MEDIO"
EXPRESSION /^MEDIO/
STYLE
END
STYLE
SYMBOL "punkt"
SIZE 6
COLOR 0 204 255
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
MINDISTANCE 20
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END
END
CLASS
NAME "S/Dato"
EXPRESSION " "
STYLE
SYMBOL "Circle"
SIZE 10
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
LABEL
TYPE truetype
FONT "DejaVuSerif"
SIZE 8
COLOR 0 0 0
#OUTLINECOLOR 0 0 0
MINDISTANCE 50
POSITION uc
ANGLE 0.00
ANTIALIAS false
BUFFER 20
END
END
END #LAYER
LAYER
NAME "gridlayer"
TYPE LINE
STATUS DEFAULT
CLASS
COLOR 0 0 0
LABEL
COLOR 0 0 0
SIZE SMALL
OUTLINECOLOR 255 255 255
END
END
GRID
LABELFORMAT "DDMM"
MININTERVAL 50000
END
END # Layer
END
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
