Mapserver PostGIS Custom SRID Problem
Paul Moen
pmoen at OFFROADSOFTWARE.COM
Tue Jan 29 13:49:17 EST 2008
I get the following error when trying to draw a layer that exists in postgis.
[MapServer Error]: msPOSTGISLayerWhichShapes(): Error executing POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from mt_counties WHERE the_geom && setSRID('BOX3D(1792876.6493994 343910,2160707.3506006 612229)'::BOX3D, 1038007 )
-ERROR: Operation on two geometries with different SRIDs
If I issue the following sql command in postgis two rows are returned rather than the error.
The custom SRID has been added to the spatial_ref_sys table in postgis and the epsg file in the proj resources. These layers display exactly the way I want when viewing with Qgis connected as postGIS layers.
Does anyone have any ideas on what I can do to further troubleshoot this? Is this a problem with mapserver, postgis, or something I am doing?
Version info.
Mac OS 10.4.11
"POSTGIS="1.2.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS"
MapServer Version MapServer version 4.10.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
PHP MapScript Version ($Revision: 1.260.2.1 $ $Date: 2006/11/22 19:34:45 $)
Thanks,
Paul
