WMS GetFeatureInfo
Richard Duivenvoorde
rdmailings at DUIF.NET
Thu Jan 31 14:50:18 EST 2008
Hi Milo,
did you succeed?
I've mapserver running here with a flamingo client example.
All configs below, hope this is helpfull:
This is de layer def from the mapfile:
LAYER
NAME pc4p
DEBUG ON
TRANSPARENCY ALPHA
TOLERANCE 15
DUMP TRUE
METADATA
"wms_title" "PC4CODE"
"wms_feature_info_mime_type" "text/html"
"gml_featureid" "oid" ## REQUIRED
"ows_feature_info_mime_type" "text/html"
"ows_include_items" "all"
#"gml_include_items" "PC4NAAM"
"gml_include_items" "all"
"wms_include_items" "all"
END # METADATA
# query templates for queries
# MUST BE AVAILABLE FOR GETFEATUREINFO REQUESTS
# responds to OGC:WMS
request=GetFeatureInfo......&info_format=text/html
HEADER "C:\ms4w\Apache\htdocs\ol\pc_header.html"
TEMPLATE "C:\ms4w\Apache\htdocs\ol\pc.html"
FOOTER "C:\ms4w\Apache\htdocs\ol\pc_footer.html"
TYPE POINT
STATUS ON
CLASSITEM 'HUISHOUDEN'
DATA pc4
PROJECTION
"init=epsg:28992"
END
CLASS
EXPRESSION ([HUISHOUDEN] > 10000)
STYLE
SYMBOL 'punt'
SIZE 60
COLOR 255 0 0
OUTLINECOLOR 255 0 0
END
END
CLASS
EXPRESSION ([HUISHOUDEN] > 2000)
STYLE
ANTIALIAS TRUE
SYMBOL 'punt'
SIZE 15
COLOR 255 0 0
END
END
This is the kind of url's flamingo is firing:
http://localhost/cgi-bin/mapserv.exe?map=test.map&REQUEST=GetFeatureInfo&SERVICE=WMS&FEATURE_COUNT=10&Y=177&X=407&SRS=EPSG:28992&VERSION=1.1.1&EXCEPTIONS=application/vnd.ogc.se_xml&INFO_FORMAT=application/vnd.ogc.gml&QUERY_LAYERS=pc4p&LAYERS=pc4p&HEIGHT=333&WIDTH=916&BBOX=-297620.12012012,300000,582620.12012012,620000
This is the gml output of mapserver which is nicely shown in flamingo:
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<pc4p_layer>
<pc4p_feature>
<gml:boundedBy>
<gml:Box srsName="EPSG:28992">
<gml:coordinates>88589.000000,463018.000000
88589.000000,463018.000000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<PC4CODE>2241</PC4CODE>
<PC4NR>2241</PC4NR>
<PC4NAAM>ZIJLWATERING EN HAVEN</PC4NAAM>
<XCOORD>88589</XCOORD>
<YCOORD>463018</YCOORD>
<PC3CODE>224</PC3CODE>
<PC2CODE>22</PC2CODE>
<PC1CODE>2</PC1CODE>
<PROVC>28</PROVC>
<PROVC_NM>Zuid-Holland</PROVC_NM>
<GEMCODE>0629</GEMCODE>
<GEMNR>629</GEMNR>
<GEMNAAM>Wassenaar</GEMNAAM>
<WOONPLAATS>WASSENAAR</WOONPLAATS>
<HUISHOUDEN>4557</HUISHOUDEN>
<NETNUMMER>070</NETNUMMER>
</pc4p_feature>
<pc4p_feature>
<gml:boundedBy>
<gml:coordinates>87278.000000,438832.000000
87278.000000,438832.000000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<PC4CODE>3125</PC4CODE>
<PC4NR>3125</PC4NR>
<PC4NAAM>INDUSTRIEGEBIED T.N.V. RIJKSWEG2</PC4NAAM>
<XCOORD>87278</XCOORD>
<YCOORD>438832</YCOORD>
<PC3CODE>312</PC3CODE>
<PC2CODE>31</PC2CODE>
<PC1CODE>3</PC1CODE>
<PROVC>28</PROVC>
<GEMCODE>0606</GEMCODE>
<GEMNR>606</GEMNR>
<GEMNAAM>Schiedam</GEMNAAM>
<WOONPLAATS>SCHIEDAM</WOONPLAATS>
<HUISHOUDEN>151</HUISHOUDEN>
<NETNUMMER>010</NETNUMMER>
</pc4p_feature>
</pc4p_layer>
</msGMLOutput>
This is the corresponding flamingo config:
<FLAMINGO xmlns:fmc="fmc" lang="en" tooltipdelay="500" >
<YGUIDE id="my" y="50%"/>
<XGUIDE id="mx" x="50%"/>
<XGUIDE id="x10" x="10"/>
<fmc:ToolGroup listento="map1" left="x10" top="10">
<fmc:ToolPan left="30" clickdelay="0" pandelay="0"/>
<fmc:ToolZoomin left="60" zoomdelay="0" clickdelay="0"/>
<fmc:ToolZoomout left="90" zoomdelay="0" clickdelay="0"/>
<fmc:ToolIdentify left="120"/>
</fmc:ToolGroup>
<!-- identify window -->
<fmc:Window left="90" top="10" width="200" height="350" visible="false"
skin="g" canclose="true" canresize="true" showresizebutton="true"
defocusalpha="70">
<string id="title" en="Informatie:"/>
<fmc:Identifyresults width="100%" height="100%" listento="map1">
<!-- progress gebeuren, bij mij (engels) zie je nu lekker niks -->
<string id="startidentify" en="" nl="Info wordt opgehaald"/>
<string id="identify" en="" nl="[progress]%"/>
<string id="finishidentify" en="" nl="Informatie"/>
<!--<string id="startidentify" en="Loading" nl="Info wordt
opgehaald"/>
<string id="identify" en="[progress]%" nl="[progress]%"/>
<string id="finishidentify" en="Information" nl="Informatie"/>-->
</fmc:Identifyresults>
</fmc:Window>
<fmc:MonitorLayer id="monitor" left="150" top="15" listento="map1"/>
<fmc:Debugger listento="map1" left="50%" top="0" height="50%"
right="right" />
<fmc:Debugger listento="pc4" left="50%" top="50%" height="50%"
right="right" />
<fmc:Map id="map1" left="0" top="0" bottom="bottom" right="75%"
visible="true" extent="-15000,300000, 300000, 620000"
fullextent="-15000,300000, 300000, 620000">
<fmc:LayerIdentifyIcon id="identifyicon" />
<fmc:LayerGrid id="grid" gridwidth="10" gridheight="10"/>
<!--<fmc:LayerOGWMS id="pc4" visible="true"
url="http://localhost/cgi-bin/mapserv.exe?map=test.map" service="WMS"
version="1.1.1" srs="EPSG:28992" query_layers="" layers="pc4"/>-->
version="1.1.1" srs="EPSG:28992" query_layers="pc4p" layers="pc4,pc4p"/>
<fmc:LayerOGWMS id="ref" visible="true"
url="http://localhost/cgi-bin/mapserv.exe?map=ontrackreferentie.map"
service="WMS" version="1.1.1" srs="EPSG:28992" query_layers=""
layers="top25,top50,top250v,nlbasis,plaatsen"/>
</fmc:Map>
</FLAMINGO>
Hope this is helpfull ;-)
Milo van der Linden wrote:
> Hello Bart,
> I think that is what I already did. Instead of feature_info_mime_type, I
> got wms_feature_mime_type; can that be a typo?
> I added feature_info_mime_type to the web section to test, but there is
> no effect, still no featureinfo. I am also posting on the flamingo-mc
> forum to see if they got some suggestions.
> In the Map section I got:
> ---- snippet ----
> WEB
> IMAGEPATH 'E:/maptemp/'
> IMAGEURL '/ms_tmp/'
> HEADER "./templates/query_header.html"
> FOOTER "./templates/query_footer.html"
> METADATA
> "wms_title" "Bouwfonds - Digitale kaart"
> "wms_onlineresource"
> "http://www.xx.xx/cgi-bin/mapserv.exe?map=E:\\mapconfig\\bouwfonds.map"
> "wms_srs" "EPSG:4326 EPSG:28992"
> "ows_schemas_location" "http://schemas.opengis.net"
> "wms_feature_mime_type" "application/vnd.ogc.gml"
> END
> END
> And for my Layer:
> ---- snippet ----
> LAYER
> NAME 'percelen'
> TYPE POLYGON
> DUMP TRUE
> TEMPLATE 'ttt'
> DATA '.\mapdata\rga\percelen_laag_poly_merged.shp'
> METADATA
> "wms_title" "percelen"
> "wms_srs" "EPSG:28992"
> "gml_featureid" "id"
> END
> STATUS ON
> TRANSPARENCY 100
> PROJECTION
> "init=epsg:28992"
> END
> CLASS
> NAME 'percelen'
> STYLE
> SYMBOL 0
> SIZE 6
> OUTLINECOLOR 180 208 208
> #COLOR 180 208 208
> END
> END
> END
> Bart van den Eijnden schreef:
>> Milo,
>> the WMS client determines the info_format. I assume QGIS is asking for
>> MIME or text/plain.
>> You need to add the following METADATA to your layers:
>> OWS_INCLUDE_ITEMS "all"
>> Maybe even GML_INCLUDE_ITEMS "all" I am not sure. Give it a try.
>> If Flamingo wants GML, it will request with
>> info_format=application/vnd.ogc.gml. If it doesn't you can probably
>> set the default/MIME format of Mapserver to this (METADATA at the WEB
>> level called feature_info_mime_type).
>> Template can remain empty, I always TEMPLATE blank.html where
>> blank.html does not even exist on the filesystem.
>> Best regards,
>> Bart
>> On Jan 30, 2008 5:48 PM, Milo van der Linden <mlinden at zeelandnet.nl
>> <mailto:mlinden at zeelandnet.nl>> wrote:
>> Hello list,
>> I have been spending 4 hours looking around the mapserver website and
>> various other resources but no luck.
>> As a Mapserver WMS client I am using flamingo-mc. flamingo-mc is
>> able to
>> perform a getFeatureInfo and requires gml as response.
>> For now I have some sort of response because with qGIS I get:
>> WMS identify result for 225, 337
>> GetFeatureInfo results:
>> Layer 'percelen'
>> Feature 507:
>> But it is clearly no gml and I haven't set the fields from the
>> table to
>> be returned.
>> So:
>> - What do I have to put in my (currently empty) TEMPLATE file?
>> - Can I enter all the GML that I need to return in my TEMPLATE and
>> does
>> anyone have a sample for this?
>> - How can I make sure that the information returned is in the gml
>> mime-type?
>> Any help would be appreciated!
>> Kind regards,
>> Milo van der Linden
