[mapserver-users] Mapscript whichshapes attribute query
Steve Lime Steve.Lime at dnr.state.mn.us
Thu Jul 3 10:00:19 EDT 2008
No, just setting the filter in the mapfile should suffice. Do you have a code snippet?
Steve
>>> "J.J. Schlafley" <jjschlafley at yahoo.com> 07/03/08 8:51 AM >>>
If I have a FILTER and FILTERITEM set in my map file for a layer....when I call a whichshapes on that layer I get zero shapes.  Comparatively, if I run a map draw, the FILTER works correctly and draws the shapes that meet the criteria.  Do I need to use mapscript to set the filter or something? Thanks
----- Original Message ----
To: mapserver-users at lists.osgeo.org; jjschlafley at yahoo.com
Sent: Wednesday, July 2, 2008 9:29:06 PM
Subject: Re: [mapserver-users] Mapscript whichshapes attribute query
Which shapes applies the layer FILTER definition if it exists. That FILTER must be set prior to calling whichshapes.
Steve
>>> "J.J. Schlafley" <jjschlafley at yahoo.com> 07/02/08 12:22 PM >>>
The mapscript documentation for the method (LayerObj) whichshapes claims you can quote: "Performs a spatial, and optionally an attribute based feature search."  How and where is the attribute based search query included in this method?
JJ
