[MAPSERVER-USERS] Odd behaviour with openlayers: think Map file error
Andrew de klerk
andrew.deklerk at gmail.com
Thu Jul 10 10:11:57 EDT 2008
Hi all
I am not sure how to explain this, but i will try my best. I have a mapfile
that works perfectly from openlayers through calling Layer.WMS. I then
modified the layer file to include a point shapefile. If I then call the
mapfile like:
http://localhost/cgi-bin/mapserv.exe?map=c:\\ms4w\\apps\\Streetmap\\ZDM.map&Mode=map
all works fine, and I see the points. If I however refresh my openlayers
map, I see the original map without the points displayed. I then tried to
clear my cache and Ctrl f5 again, but still the same problem. I then changed
my openlayers from Layer.WMS to Layer.MapServer and tried, but still the
same problem. As a final test I changed it to Layer.MapServer.Untiled, and I
could see the points....that is until I zoom in, then the points dissapear.
So what is the problem? Is it possibly a map file error?,
I will give an extract of my mapfile and the offending layer.
I must also add that the file did get corrupt at one stage, but I did have a
backup in projected file, which I did reproject to WGS84 (essentially
re-creating it)...but I have no gaurantee that the backup file is not
corrupted...so could all this be the fault of a corrupt shapefile??
Anyway, here is the layer extract and the header of my mapfile:
LAYER
NAME 'Scheme_Components'
TYPE POINT
DATA 'Infrastructure\Scheme_Components'
METADATA
'wms_title' 'Scheme_Components'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
"init=epsg:4148"
END
CLASS
MINSCALE 1
MAXSCALE 5000000
NAME 'Communal Standpipe'
STYLE
SYMBOL 'Triangle'
SIZE 7
COLOR 182 120 174
END
END
END
MAP
NAME 'ZDM'
SIZE 600 500
UNITS dd
SHAPEPATH "D:\ZDM\basedata\"
#CONFIG "PROJ_LIB" "D:\WWW\WMSMapServer\ms4w\proj\nad\"
CONFIG "PROJ_LIB" "C:\ms4w\proj\nad\"
FONTSET "Fonts/fonts.txt"
SYMBOLSET "Symbols/symbols.sym"
EXTENT 29.739840 -28.780849 32.845078 -26.922820
PROJECTION
"init=epsg:4148"
END
OUTPUTFORMAT
NAME 'AGG_JPEG'
DRIVER AGG/JPEG
IMAGEMODE RGB
FORMATOPTION "QUALITY=90"
END
#Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 16 10
LABEL
TYPE truetype
ANTIALIAS true
FONT arial
SIZE 9
COLOR 0 0 0
BUFFER 1
PARTIALS false
MINDISTANCE 500
END
END
SCALEBAR
COLOR 0 0 0
INTERVALS 3
LABEL
TYPE truetype
ANTIALIAS true
FONT arial
SIZE 7
COLOR 0 0 0
BUFFER 1
PARTIALS false
MINDISTANCE 500
END
OUTLINECOLOR 0 0 0
POSTLABELCACHE TRUE
POSITION LL
SIZE 120 4
STATUS ON
STYLE 0
UNITS KILOMETERS
END
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
#IMAGEPATH 'D:\ApplicationTemp\'
IMAGEPATH 'D:\Inetpub\Uploads\Temp'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL 'Temp/'
# WMS server settings
METADATA
'wms_title' 'ZDM'
'wms_onlineresource' 'http://wms.mapexchange.co.za/qwms/qwms.aspx?'
'wms_srs' 'EPSG:4148'
END
TEMPLATE "Streetmap.html"
END
View this message in context: http://www.nabble.com/Odd-behaviour-with-openlayers%3A-think-Map-file-error-tp18383538p18383538.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
