[mapserver-users] New limitations with mapserver 5 CGI
Paul Ramsey pramsey at cleverelephant.ca
Fri Jul 11 00:32:18 EDT 2008
Well, yes, but you have to understand, I'm very very lazy :)
P
On Thu, Jul 10, 2008 at 10:24 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Paul Ramsey wrote:
>> I'd like to see backwards feature compatibility available, and I think
>> the CGI override controller is one of the most powerful
>> (under-appreciated) features of Mapserver.
>> Since the control of what is over-rideable is in the lexer though,
>> we're sort of in a narrow box. We could do a compile-time option,
>> which would allow us to default to strict but allow (relatively) easy
>> conversion to flexible. That wouldn't really help our Windows brethren
>> though, since they mostly rely on pre-compiled versions, and binary
>> maintainers don't maintain lots of different builds.
>> Having a map-level run-time directive to control the availability of
>> URL over-rides would be the ideal, IMO.  Default, NONE.  Other
>> options, STRICT and FULL.  However, I don't see how to get there from
>> here with the lexer requirement.
> Paul,
> I think you would just build it with the lexer support always enabled but
> have the runtime restrict access to the feature based on the
> NONE|STRICT|FULL control flag.
> -Steve W
>> P.
>> On Thu, Jul 10, 2008 at 6:05 PM, Graeme Watmuff
>> <gwatmuff at geographicweb.com.au> wrote:
>>> Hi Steve,
>>> Thanks for replying and thanks for the coding pointers. You are right
>>> about the mapserv 4.10 tileindex syntax. Like filter, it is simply
>>> ignored by v5 rather than throwing an error. My apologies.
>>> Would it make sense to create a 'secure' version for the paranoid and a
>>> another version with full functionality? I realize this would create
>>> more maintenance work for you, but not all mapserver users are going to
>>> be able to climb inside the code themselves to modify functionality
>>> (fortunately we can).
>>> Regarding security, I presume you are concerned about mapserver exposing
>>> sensitive data to unintended users. If so, should you be taking that
>>> responsibility on yourself by limiting mapserver or should the onus be
>>> upon mapserver users to manage their own data more responsibly? I am a
>>> great believer in personal responsibility. If the security risk is made
>>> clear to users, they can make their own decisions as to the data they
>>> potentially expose to the world.
>>> We have greatly appreciated and benefited from the tremendous work you
>>> and your associates have done in bringing mapserver to the world and we
>>> have always looked forward to the added features of each new version.
>>> But upgrading now comes at some degree of inconvenience for us and maybe
>>> others unless someone wants to publish the workaround to resurrect lost
>>> functionality for all to simply acquire.
>>> I am not convinced that limiting the previous functionality is the right
>>> direction for mapserver unless you fear say a litigious threat from
>>> security breaches that people may bring upon themselves (hardly your
>>> responsibility). Those with seriously sensitive data are not going to
>>> want expose the CGI to all the world via a browser-sent URL anyway. I
>>> would expect them to send URLs from say, a java web app embedded in a
>>> secured tomcat container.
>>> Just my thoughts.
>>> Regards and best wishes
>>> Graeme
>>> On Thu, 2008-07-10 at 17:13 -0500, Steve Lime wrote:
>>>> Hi Graeme: Comments inline... I definitely underestimated the impacts of
>>>> those
>>>> changes. Anyway...
>>>>>>> On 7/9/2008 at 11:23 PM, in message
>>>> <1215663787.2513.112.camel at bongolx.ringo.net>, Graeme Watmuff
>>>>> It has become apparent through some frustrating moments of trial and
>>>>> error that many of the mapfile variables that were changeable via URL
>>>>> with mapserver 4.10.x CGI seem no longer changeable with v5.x or 5.2.x.
>>>>> There is a hint from the docs that this is because of security
>>>>> concerns?
>>>>> Our java apps don't allow web users to directly interact with the CGI,
>>>>> so security doesn't seem so important in our case.
>>>> Allowing unaltered, direct modification of things like FILTERs or
>>>> CONNECTIONS
>>>> is a potential security risk although I've never run across a documented
>>>> case. Filters
>>>> are risky because they are passed to the underlying data driver which
>>>> generally
>>>> trust the contents.
>>>>> Some examples:
>>>>> map_web_metadata='text1' 'text2'
>>>>> map_layerName_filter=<expression>
>>>>> map_layerName_tileindex=<tileindex.shp>
>>>>> map_layerName_data=<datasource>
>>>>> allow changes to the mapfile via URL with mapserver 4.10.x
>>>>> Following the new syntax specified for v5 + I had expected
>>>>> map_web=metadata+"'text1' 'text2'" or maybe
>>>>> map_web_metadata[0]='text1'+'text2',
>>>>> map_layer[layerName]=filter+<expression>,
>>>>> map_layer[layerName]=tileindex+<tileindex.shp>,
>>>>> map_layer[layerName]=data+<datasource>
>>>>> to all perform in the time-honoured way.
>>>> And they don't... If they did you could combine modifications to a layer
>>>> in a single
>>>> variable:
>>>>  map_layer[layerName]=filter+<expression>+tileindex+<tileindex.shp>+data+<datasource>
>>>>> Only 'data' could be changed with this new mapserver 5 syntax. I
>>>>> happened to discover through the change logs that changing tileindex
>>>>> was
>>>>> reinstated for mapserver 5 CGI, but using the old mapserver 4.10 syntax
>>>>> (map_layerName_tileindex)=<tileindex.shp> - not the new mapserver 5
>>>>> syntax style (map_layer[layerName]=tileindex+<tileindex.shp>).
>>>> Looking at the code, TILEINDEX is not changable via a URL with any
>>>> syntax. The
>>>> change log references a bug fix to 4.10. The old syntax doesn't work at
>>>> all.
>>>>> mapserv 5 CGI throws an error (Parsing error near (filter)) when the
>>>>> new
>>>>> syntax is used for filter and ignores the old 4.10 filter syntax.
>>>> This is expected. It will fail with an error as opposed to the silent
>>>> failure of versions
>>>> past.
>>>>> No URL syntax for changing the web object's metadata content appears
>>>>> acceptable to the mapserver 5.
>>>> Correct.
>>>>> I would dearly like to see changing the layer filter via URL restored
>>>>> also to mapserver 5. And the web object's metadata setting
>>>>> functionality
>>>>> too.
>>>> It's possible to customize this behavior by editing maplexer.l and
>>>> recompiling
>>>> the code. Simply find the keyword you're interested in supporting and
>>>> change
>>>> the states at which it is valid. So, for TILEINDEX:
>>>> <INITIAL>tileindex
>>>> becomes:
>>>> <INITIAL,URL_STRING>tileindex
>>>> Same goes for the other parameters you'd want to activate.
>>>>> Can anyone indicate what mapfile properties are or are not going to be
>>>>> reinstated in mapserver 5 compared to mapserver 4 for change via URL?
>>>>> Obviously this has development ramifications for us when we try to
>>>>> upgrade mapserver.
>>>> If I (or anyone) can think of a way to make this tunable at runtime I'd
>>>> love
>>>> to talk more about it. The set of parameters supported in 5.2 has only
>>>> changed
>>>> a little bit since 5.0 based on user input. I can't see exposing more
>>>> without
>>>> good reason. FILTER in particular is worrisome and there is a work
>>>> around with
>>>> the runtime substitution (e.g. FILTER %someval%). In that example you
>>>> can
>>>> pass someval via URL but you have to define a validation pattern (a
>>>> regex) to
>>>> check it against.
>>>>> Alternatively, am I missing something with new mapserver 5 syntax?
>>>> I'm curious if updating maplexer.l to fit your particular needs is
>>>> workable.
>>>>> Graeme Watmuff
>>>> Steve
>>> Graeme Watmuff
>>> Geographic Web Solutions Pty Ltd
>>> 17 Tay Road
>>> Woodforde
>>> South Australia  5072
>>> ph:  + 61 8 83364463
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
