[MAPSERVER-USERS] Connection parameter errors while using
Postgres DB Schema
ritesh ambastha
ritesh.linux at gmail.com
Wed Jul 16 05:52:18 EDT 2008
Venkat,
I am looking for that "some setting" :)
Cheers,
Ritesh
On Wed, Jul 16, 2008 at 3:23 PM, Venkat Rao Tammineni <
vtammineni at roulacglobal.com> wrote:
> Hi,
> Have you checked other schema? See you can use either public or pg_temp_1
> right ? if you want to use pg_temp_1 schema u need to have some setting
> while configuring at add new server connection. This is only as per
> knowledge. I did not tested. And my suggestion is Use "Pulic".Because ,if
> there any joining among the table ,that would be again problem.
> If I am not right ,let me know.
> Thanks and Regards
> Venkat.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ritesh
> Ambastha
> Sent: Wednesday, July 16, 2008 3:07 PM
> To: mapserver-users at lists.osgeo.org
> Subject: RE: [MAPSERVER-USERS] Connection parameter errors while using
> Postgres DB Schema
> Hey Venkat,
> Thanks for the details.
> I understand the standard way to write a connection parameter.
> I am sure that this table "rgp_gis_gmm_100_metros" is stored in "public"
> schema of your database.
> My question is, what will you write if you keep this table in some other
> schema?
> Regards,
> Venkatrao wrote:
> > Hi,
> > Here is my Example .I think it helps you.
> > Layer # Layer starts here
> > Name "GMM 100" #name of the layer
> > ConnectionType POSTGIS #connection type
> > Connection "host=192.168.1.158 dbname=GIS password=administrator
> > user=postgres port=5432" #connection type.
> > Data "the_geom from rgp_gis_gmm_100_metros" #table name
> > Thanks and Regards
> > Venkat.
> > Ambastha
> > Sent: Wednesday, July 16, 2008 2:44 PM
> > Subject: [MAPSERVER-USERS] Connection parameter errors while using
> > Postgres
> > DB Schema
> > Hello Readers,
> > I am facing a problem in defining the DATA path in mapserver while using
> > PostGIS.
> > I have two schemas, lets say 'a' and 'b' in a database 'd'
> > Now, I want to access tables of schema 'a' in the mapserver layer.
> > I define DATA path like this:
> > DATA "the_geom FROM a.table_name USING UNIQUE id SRID -1"
> > Please pour in your thoughts for defining schema in the connection/data
> > parameters.
> > Thanks,
> > Ritesh Ambastha
> > View this message in context:
> http://www.nabble.com/Connection-parameter-errors-while-using-Postgres-DB-Sc
> > hema-tp18483547p18483547.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> hema-tp18483547p18483876.html<http://www.nabble.com/Connection-parameter-errors-while-using-Postgres-DB-Schema-tp18483547p18483876.html>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080716/ce85492e/attachment-0001.html
