[mapserver-users] Trouble with a Share Point Portal.
[SEC=UNCLASSIFIED]
Roppola, Antti - BRS
Antti.Roppola at brs.gov.au
Wed Jul 16 21:00:13 EDT 2008
Hi all,
For Java bindings (about a year ago), we found that using a current
version of SWIG to re-build the pre-canned SWIG interface gave a
better result. Before this we has issues with SWIG doing things like
flattening structs.
We identified and solved the problem by intercepting and inspecting
the map objects that threw the exception to ensure they contained
what the API said they ought to contain.
Cheers,
Antti
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
Sent: Thursday, 17 July 2008 5:46 AM
To: Pietro Giannini
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Trouble with a Share Point Portal.
Pietro,
Could you provide a code sample to investigate the problem in more detail?
Best regards,
Tamas
2008/7/16 Pietro Giannini <pgiannini at bytewise.it>:
> Hi all,
> I'm in serious trouble with the ambitious project of a web mapping app
> in a Windows SharePoint Services 3.0 environment; in detail, the
> application is embedded in a web part.
> Obviously, I'm developing in c#, that is not my preferred...
> I've recompiled myself mapserver and the mapscript_csharp assembly. In
> a debug environment all works fine but when I deploy the web part on
> the server I allways receive the same error:
> - Exception of type: System.TypeInitializationException;
> - with the message: "The type initializer for 'OSGeo.MapServer.mapscript'
> threw an exception";
> - the source: mapscript_csharp;
> - the InnerException.StackTrace is:
> -- at OSGeo.MapServer.mapscriptPINVOKE.MAX_ERROR_LEN_get()
> -- at OSGeo.MapServer.mapscript..cctor()
> If anyone has experienced the same or a similar problem, or has more
> experience than me, can please help me?
> thanks in advance.
> ..........................................pg
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain sensitive and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
