[mapserver-users] Data for Mapserver.
TC Haddad
tchaddad at gmail.com
Tue Jul 22 17:57:22 EDT 2008
You need to look at the .prj file and see what the projection of the data
is, and compare it to your map file extents.
It is possible that you can't see the data at the moment because it is in a
different coordinate space, and lies outside of the extents of your current
map.
Tanya
2008/7/22 Νικος Παπαδάκης <nipapada at gmail.com>:
> Is there any way i can find out what layers do these files contain?
> Because i can retrieve a map ,but an empty map...
> I tried to read the data using ogr writing in the mapfile
> LAYER
> NAME "city"
> STATUS DEFAULT
> TYPE line
> CONNECTIONTYPE OGR
> CONNECTION v_roads_arc.shp
> CLASS
> STYLE
> COLOR 0 0 0
> END
> END
> END
> but unfortunately the result is the same...
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080722/4bf04ef4/attachment.html
