[mapserver-users] KML thematics from MS Layers
Christopher Condit
condit at sdsc.edu
Tue Jun 3 18:04:25 EDT 2008
Hi Sarel-
I’m not sure why I didn’t see your GDAL-dev post…
I don’t know of any way to do this with MapServer, but you can come close with a combination of OGR and XSL. I wrote a post on this a while ago on the gdal wiki here: http://trac.osgeo.org/gdal/wiki/KML
So essentially you’d export to KML using ogr2ogr and then customize the styling based on your needs. You could even generate the XSL file dynamically if you needed to…
-Chris
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sarel Coetzer
Sent: Monday, June 02, 2008 5:09 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] KML thematics from MS Layers
Hi
Need some advice on how to create thematic looking KML layers from MapServer layers that is classified in 5 thematic classes.
This is a long shot and might be the wrong forum but I haven't had success in the GDAL or OGR forums
Sarel
"http://sarelgis.blogspot.com/"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080603/80e97834/attachment.html
