[mapserver-users] Q: MapServer(ms4w) works with tomcat instead of apache
Andrew Mason andrew at environ-it.co.uk
Wed Jun 4 11:11:57 EDT 2008
Hello,
Tomcat and Apache are very different things, and while there is
certainly a degree of overlap in what Apache Httpd and Apache Tomcat
can be used for, the way the two applications actually operate is
very different.
Without going in to too much detail here, Tomcat is essentially a
J2EE application container, not a webserver and applications are
written using the Java programming  language. You'd normally never
use Tomcat to serve files in the way you'd use Apache httpd. You'd
normally delegate such a task to a webserver. And there really isn't
much of an issue about having the two servers installed, we sorted
out the port conflict issues a while back.
Excuse any slight errors here, I've only been using Mapserver a few
weeks myself, but my understanding is that Mapserver essentially a
set of C libraries that are accessible via CGI. You can also access
these via  PHP, Python and others even Java it seems, using
mapscript. But being able to script in Java is still a long way from
being able to deploy to a servlet container like Tomcat.
If you really want to avoid installing Apache httpd, then you might
find Geoserver useful, as it is a Java web application, and deploying
it to Tomcat is really easy.
But I would recommend trying Apache Httpd, as it's not particularly
difficult to get to grips with.
Hope this helps,
regards
Andrew Mason
On 4 Jun 2008, at 10:12, Zhao Ying (CDU) wrote:
> Hello,
> I’m Jeff from Sichuan, China. I have a question about how to
> configure MapServer so that it could be
> able to work with apache-tomcat-5.5.26 instead of apache by
> default. Since I’ve already had tomcat 5.5.26
> installed on my computer and tomcat is well known as both Web
> server and application server,
> it seems there’s no need to install one more web server – apache.
> Furthermore, more web servers, more
> possibilities to conflict, such as listing ports …, right?
> Could somebody provide a solution in details on how to achieve
> this? Thanks!! ~~
> Btw, my computer environment:
> Windows XP;
> JDK 1.4;
> apache-tomcat-5.5.26; installed on c:\ apache-tomcat-5.5.26
> ms4w_2.2.7.zip downloaded from http://maptools.org/ms4w/ and
> unzipped to c:\ms4w
> Regards,
> Jeff.
> Legal Disclaimer: The information contained in this message may be
> privileged and confidential. It is intended to be read only by the
> individual or entity to whom it is addressed or by their designee.
> If the reader of this message is not the intended recipient, you
> are on notice that any distribution of this message, in any form,
> is strictly prohibited. If you have received this message in error,
> please immediately notify the sender and delete or destroy any copy
> of this message
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080604/411b959e/attachment.html
