[mapserver-users] Label attribute bindings
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jun 5 16:52:17 EDT 2008
Tim,
Well in that case you should be able to set CLASSITEM to your position
attribute. And then set up a CLASS for each position. This is UGLY in
the mapfile, but you should be able to do it now without code changes.
-Steve
Tim Urwin wrote:
> Hi Steve,
> Unfortunatly not, it is a single digit 1-9 in an attribute field which
> we mapped to the two letter characters used by mapserver for text
> position, eg ll cc etc. We would just like to be able to look this up
> for each feature rather than apply a blanket approach for the layer. We
> would prefer not to edit the data as it changes get updated on a regular
> basis (we get updates every 6 to 8 weeks from ordnance suervey) and the
> database table has just under 22 and a half million entries.
> Thanks
> Tim
> Stephen Woodbridge wrote:
>> Tim,
>> When you say "OS has determined the best position for the label", what
>> form is this attribute in? Is the x-y position attribute columns? or
>> some offset x-y attribute? or what?
>> If it is an x-y position that you would rather use that the default
>> the_geom geometry position of the feature then it would probably be
>> possible to create a view that makes that x-y appear as
>> setsrid(makepoint(x_col,y_col),27700) as the_geom in the view and then
>> add a record to the geometry_columns table for this view. for
>> performance you might want to add this column to the orginal table and
>> index it.
>> Then you should be able to renter the annotation using the view or the
>> alternate column in the table.
>> -Steve W
>> Tim Urwin wrote:
>>> Hi all,
>>> This is a questuion about label attribute bindings.
>>> We are about to migrate some of our Ordnance Survey MasterMap data
>>> from a propriety system to using mapserver serving the data from a
>>> PostGIS database for screen maps. We are currently using Mapserver
>>> 5.02 and are very happy with the results we have achieved so far,
>>> however, due to only being able to set a single value for the
>>> position of a label has caused much of the text to be badly
>>> misaligned with the underlying features.
>>> OS has determined the best position for the label and provide this as
>>> attribute data for each text label point and we would like to be able
>>> to utilise it. Is there anyway to make the position label attribute
>>> accept a binding as some of the other values do, e.g. angle which we
>>> also use. The problem we have is that no single value works with the
>>> data to provide a good map result, therefore we would like to be able
>>> to use each feature's value as opposed to a global value.
>>> Any help or insights in how to achieve this will be gratefully
>>> received. At the moment our applications access Mapserver via CGI
>>> mode directly without the use of mapscript although we could
>>> investigate that option.
>>> The following is an example of one of the entries in the mapfile for
>>> a label layer.
>>> LAYER
>>>   NAME "Heritage labels"
>>>   METADATA
>>>      "wms_title" "Heritage labels"
>>>      "wms_srs"   "EPSG:27700"
>>>      "wms_extent"   "0.0 0.0 700000.0 1300000.0"
>>>   END
>>>   STATUS OFF
>>>   CONNECTIONTYPE postgis
>>>   CONNECTION "user=XXXX password=XXXX dbname=XXXX host=XXXX port=XXXX"
>>>   DATA '"anchorpoint" from "cartographictext" using unique "fid"
>>> using SRID=27700'
>>>   PROCESSING    "CLOSE_CONNECTION=DEFER"
>>>   TYPE Annotation
>>>   LABELITEM 'textstring'
>>>   FILTER ("layer" = '59')
>>>   CLASS
>>>      NAME 'Antiquity Text (82)'
>>>         LABEL
>>>           COLOR     0 0 0
>>>           OUTLINECOLOR 255 255 255
>>>           TYPE      TRUETYPE
>>>           FONT      arial-italic
>>>           SIZE      8
>>>           ANGLE  [angle]
>>>           ANTIALIAS TRUE
>>>           POSITION  CC
>>>           PARTIALS  TRUE
>>>           ENCODING 'UTF-8'
>>>         END
>>>   END
>>>   MINSCALEDENOM 100.0
>>>   MAXSCALEDENOM 5500.0
>>>   PROJECTION
>>>   "init=epsg:27700"
>>>   END
>>> END
>>> many thanks
>>> Tim
