[MAPSERVER-USERS] help! agg palette quantize
algorithm imperfection
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 6 11:00:24 EDT 2008
Hey, that's what they pay you the BIG BUCKS for! :)
Write a perl/bash/{your favorite} script to grab all the COLOR lines
from you mapfile and reformat the r g b to r,g,b in you palette file.
I have a few hundred symbols in my symbol library, but I only use about
10 of them regularly so I made sure the primary colors were also in the
palette file. I make the script add them so I don't have to think about it.
It sounds like a big deal, but it not that bad.
YMMV,
-Steve W
BrainDrain wrote:
> Thanks, i already read about preparing palette index file & I see 2
> obstacles:
> 1) I need to monitor my map file (big size) to keep relevant my palette
> file. It is inflexible to extract rgb colors used in pixmap symbols
> (hundreds, updatable). Can I use html palette for ex. (or any other
> 'universal' palette) - to make this process not so time-consuming?
> 2) If I have strict palette, can I be sure that agg renderer will always use
> the nearest(?) color from my palette?
> pagameba wrote:
>> Use:
>> OUTPUTFORMAT
>> OUTPUTFORMAT
>> NAME "AGG_Q"
>> DRIVER "AGG/PNG"
>> MIMETYPE "image/png; mode=8bit"
>> IMAGEMODE RGB
>> EXTENSION "png"
>> FORMATOPTION "PALETTE_FORCE=TRUE"
>> FORMATOPTION "PALETTE=/path/to/palette.txt"
>> END
>> where palette.txt is a text file with RGB tuples in the form:
>> RRR,GGG,BBB
>> For example:
>> 0,0,0
>> 255,255,255
>> 127,127,127
>> MapServer will use AGG 24 bit rendering but reduce the output file to
>> 8 bit and reserve the colours in your palette.txt file. This will
>> give you consistent colours for the ones you care about.
>> Specifically, you should reserve all the colours that you actually
>> reference in your map file plus any colours of pixmap symbols. Don't
>> put in more colours than you actually need to because MapServer needs
>> to use whatever space is left (255 less your colours) for antialiasing.
>> Cheers
>> Paul
>> On 6-Jun-08, at 7:53 AM, BrainDrain wrote:
>>> I use this output format in my map file:
>>> OUTPUTFORMAT
>>> NAME "AGG_Q"
>>> DRIVER "AGG/PNG"
>>> IMAGEMODE RGB
>>> EXTENSION "png"
>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>> FORMATOPTION "QUANTIZE_COLORS=256"
>>> END
>>> but every time map draw called (or map image requested fom cgi
>>> mapserv.exe)
>>> polygons has a little difference in fill color (I think this is
>>> because
>>> color palette recalculated slightly different each time). This is
>>> unacceptable for me. How can i correct this? (maybe some
>>> FORMATOPTION?)
>>> View this message in context:
>>> http://www.nabble.com/help%21-agg-palette-quantize-algorithm-imperfection-tp17667733p17667733.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://www.dmsolutions.ca/
