[mapserver-users] SLD implementation - fill-opacity
Guillaume Sueur guillaume.sueur at neogeo-online.net
Fri Jun 6 10:19:40 EDT 2008
Hi, Assefa,
Do you mean I have to use AGG to get benefit from opacity settings in SLD ?
Thanks
Yewondwossen Assefa a écrit :
> Hi there,
>  Actually the style->opacity parameter was there for a while although
> not used until recently. The SLD (mapserver svn) already reads the
> stoke/fill-opacity and set the parameter. Note that this only the AGG
> output supports opacity at style level.
>  Please report an issue through bug 2638 if opacity with AGG output is
> not working as expected.
> Best Regards,
> bartvde at osgis.nl wrote:
>> I am quite sure this is because back then Mapserver only supported
>> layer-level transparency, and not style-level transparency.
>> With the new addition of style-level transparency in trunk, it should
>> become possible to implement this now AFAICT. Maybe open up an
>> enhancement
>> ticket for this?
>> Best regards,
>> Bart
>> On Fri, 06 Jun 2008 14:52:28 +0200, Guillaume Sueur
>> <guillaume.sueur at neogeo-online.net> wrote:
>>> Hi folks,
>>> Does Mapserver SLD implementation supports the fill-opacity css
>>> parameter ? As far as I can see, it doesn't. Bug ?
>>> Thanks
>>> Guillaume
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
