[mapserver-users] SLD implementation - fill-opacity
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Jun 6 16:51:40 EDT 2008
Guillaume,
Yes :support in AGG for the style opacity is only available in the
last svn trunk (http://trac.osgeo.org/mapserver/ticket/1155)
Besr Regards,
Guillaume Sueur wrote:
> I still don't have a the desired rendering, even with AGG... I'm using
> 5.0.1 dev version, should I upgrade to the last SVN version ?
> thanks
>>> Hi, Assefa,
>>> Do you mean I have to use AGG to get benefit from opacity settings in
>>> SLD ?
>>> Thanks
>> Yesy : the SLD will always parse and set the style's opacity parameter.
>> But since only the AGG output uses it when rendering the map, you
>> would need to set your output to AGG to see the effects.
>>>> Hi there,
>>>> Actually the style->opacity parameter was there for a while
>>>> although not used until recently. The SLD (mapserver svn) already
>>>> reads the stoke/fill-opacity and set the parameter. Note that this
>>>> only the AGG output supports opacity at style level.
>>>> Please report an issue through bug 2638 if opacity with AGG output
>>>> is not working as expected.
>>>> Best Regards,
>>>> bartvde at osgis.nl wrote:
>>>>> I am quite sure this is because back then Mapserver only supported
>>>>> layer-level transparency, and not style-level transparency.
>>>>> With the new addition of style-level transparency in trunk, it should
>>>>> become possible to implement this now AFAICT. Maybe open up an
>>>>> enhancement
>>>>> ticket for this?
>>>>> Best regards,
>>>>> Bart
>>>>> On Fri, 06 Jun 2008 14:52:28 +0200, Guillaume Sueur
>>>>> <guillaume.sueur at neogeo-online.net> wrote:
>>>>>> Hi folks,
>>>>>> Does Mapserver SLD implementation supports the fill-opacity css
>>>>>> parameter ? As far as I can see, it doesn't. Bug ?
>>>>>> Thanks
>>>>>> Guillaume
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
