[MAPSERVER-USERS] help! agg palette quantize algorithmimperfection
BrainDrain
paulborodaev at gmail.com
Sat Jun 7 09:35:13 EDT 2008
hmmm, like sample map image with all layers (and most symbols) turned on?
sounds reasonable
That would be enough? (not all colors in sample: the nearest colors will be
used?) Sorry for importunity.
Steve Lime wrote:
> I've generated palettes by rendering a large 24-bit sample image and then
> reducing colors using
> tools like Photoshop, GIMP or ImageMagick. Then I just run gdalinfo output
> on the reduced color
> image through a perl script to extract the palette.
> #!/usr/bin/perl
> $doit = 0;
> while(<>) {
> if($_ =~ /Color Table/) {
> $doit = 1;
> next;
> if($doit) {
> ($r,$g,$b,$a) = split /,/, substr($_,7);
> print "$r,$g,$b\n";
> Works just fine...
> Steve
>>>> On 6/6/2008 at 3:24 PM, in message <17700473.post at talk.nabble.com>,
>>>> BrainDrain
> <paulborodaev at gmail.com> wrote:
>> $? You're kidding)) Anyway, thanks for advise. Will try.
>> And what about agg rgba mode (bug, invalid color interpretation
>> (inverting?)
>> or something like that)? When
>> this problem will be fixed? I need it, because I want to use map
>> transparency (only rgba mode) to combine with google map layer in
>> openlayers
>> rich client app.
>> Stephen Woodbridge wrote:
>>> Hey, that's what they pay you the BIG BUCKS for! :)
>>> Write a perl/bash/{your favorite} script to grab all the COLOR lines
>>> from you mapfile and reformat the r g b to r,g,b in you palette file.
>>> I have a few hundred symbols in my symbol library, but I only use about
>>> 10 of them regularly so I made sure the primary colors were also in the
>>> palette file. I make the script add them so I don't have to think about
>>> it.
>>> It sounds like a big deal, but it not that bad.
>>> YMMV,
>>> -Steve W
>>> BrainDrain wrote:
>>>> Thanks, i already read about preparing palette index file & I see 2
>>>> obstacles:
>>>> 1) I need to monitor my map file (big size) to keep relevant my palette
>>>> file. It is inflexible to extract rgb colors used in pixmap symbols
>>>> (hundreds, updatable). Can I use html palette for ex. (or any other
>>>> 'universal' palette) - to make this process not so time-consuming?
>>>> 2) If I have strict palette, can I be sure that agg renderer will
>>>> always
>>>> use
>>>> the nearest(?) color from my palette?
>>>> pagameba wrote:
>>>>> Use:
>>>>> OUTPUTFORMAT
>>>>> OUTPUTFORMAT
>>>>> NAME "AGG_Q"
>>>>> DRIVER "AGG/PNG"
>>>>> MIMETYPE "image/png; mode=8bit"
>>>>> IMAGEMODE RGB
>>>>> EXTENSION "png"
>>>>> FORMATOPTION "PALETTE_FORCE=TRUE"
>>>>> FORMATOPTION "PALETTE=/path/to/palette.txt"
>>>>> END
>>>>> where palette.txt is a text file with RGB tuples in the form:
>>>>> RRR,GGG,BBB
>>>>> For example:
>>>>> 0,0,0
>>>>> 255,255,255
>>>>> 127,127,127
>>>>> MapServer will use AGG 24 bit rendering but reduce the output file to
>>>>> 8 bit and reserve the colours in your palette.txt file. This will
>>>>> give you consistent colours for the ones you care about.
>>>>> Specifically, you should reserve all the colours that you actually
>>>>> reference in your map file plus any colours of pixmap symbols. Don't
>>>>> put in more colours than you actually need to because MapServer needs
>>>>> to use whatever space is left (255 less your colours) for
>>>>> antialiasing.
>>>>> Cheers
>>>>> Paul
>>>>> On 6-Jun-08, at 7:53 AM, BrainDrain wrote:
>>>>>> I use this output format in my map file:
>>>>>> OUTPUTFORMAT
>>>>>> NAME "AGG_Q"
>>>>>> DRIVER "AGG/PNG"
>>>>>> IMAGEMODE RGB
>>>>>> EXTENSION "png"
>>>>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>>>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>>>>> FORMATOPTION "QUANTIZE_COLORS=256"
>>>>>> END
>>>>>> but every time map draw called (or map image requested fom cgi
>>>>>> mapserv.exe)
>>>>>> polygons has a little difference in fill color (I think this is
>>>>>> because
>>>>>> color palette recalculated slightly different each time). This is
>>>>>> unacceptable for me. How can i correct this? (maybe some
>>>>>> FORMATOPTION?)
>>>>>> View this message in context:
>> http://www.nabble.com/help%21-agg-palette-quantize-algorithm-imperfection-tp1766773
>> 3p17667733.html
>>>>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>> Paul Spencer
>>>>> Chief Technology Officer
>>>>> DM Solutions Group Inc
>>>>> http://www.dmsolutions.ca/
View this message in context: http://www.nabble.com/help%21-agg-palette-quantize-algorithm-imperfection-tp17667733p17708955.html
