[mapserver-users] mapserver wms: srs problem
Matthew Pettis matthew.pettis at gmail.com
Sat Jun 7 20:21:25 EDT 2008
I am not a GIS guy, and am a bit confused by the projection attributes
i have to specify in mapserver.  In particular, I have a simple
example.  I have a map that has the following metadata:
Horizontal Coordinate Scheme   	 UTM
Ellipsoid 	GRS80
Horizontal Datum 	NAD83
Horizontal Units 	Meters
UTM Zone Number 	15
I believe this translates to an epsg=26915
Now, according to mapserver, I have to specify a projection object, a
web metadata srs, and a layer metadata srs.
To compress the mapfile, i'll just note what i have specified for each
of these settings.
First, I would think that this would work:
projection => init=epsg:26915
web metadata srs => EPSG:26915
layer metadata srs => EPSG:26915
this give me the error:
msWMSLoadGetMapParams(): WMS Server Error. Invalid SRS given.  SRS
must be valid for all requested layers.
I only have the one layer (it's of the state of MN from www.gis.leg.mn).
However, the following renders, but I don't think it is the projection
i want (as the top of MN is too wide):
layer metadata srs => EPSG:4326
Now, I am using mapserver as a WMS.  Before I was using it NOT as a
WMS, but just making it render the shapefile without any projection
information, it worked, and it was the projection I had come to expect
when seeing the state of MN rendered.
Why does my first configuration give me an error?
How can I make it render in the way I expect without giving mapserver
explicit projection instructions?
please forgive the ignorance of map projection knowledge.
thanks,
matt
It is from the wellspring of our despair and the places that we are
broken that we come to repair the world.
-- Murray Waas
