[mapserver-users] Dynamically changing processing directive using
CGI parameter?
John Maurer
maurerj at nsidc.org
Mon Jun 9 11:20:10 EDT 2008
I'm using MapServer 4.99 and trying to modify the processing directive
for a raster layer dynamically using a CGI parameter. I want to let the
user modify the min and max values used to scale the image. I've tried
lots of different syntaxes for this without any success. Anybody know
the trick? I've tried the following:
&map_layername_processing="scale=15000,17000"
&map_layername_processing="scale%3D15000%2C17000"
&map_layername_processing=scale%3D15000%2C17000
&map_layername_processing_0=/all of the above.../
&map_layername_processing_scale=15000,17000
&map_layername_processing_scale=15000%2C17000
&map_layername_processing_scale=15000+17000
&map_layername_processing_0_scale=/all of the above.../
Is this something that's not possible to modify dynamically? Thanks for
any help!
Best Regards,
John Maurer
John Maurer
Web/Database Applications Engineer
National Snow and Ice Data Center (NSIDC)
University of Colorado at Boulder
http://cires.colorado.edu/~maurerj
"Without geography, you're nowhere!"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080609/baf4457d/attachment.html
