[mapserver-users] show legend graphic with mapbuilder 1.5 andmapserverUID 4386)
bartvde at osgis.nl bartvde at osgis.nl
Tue Jun 10 08:29:05 EDT 2008
I think you are missing the required parameter VERSION in your
GetLegendGraphic URL.
http://localhost/cgi-bin/mapserv.exe?map=d:/www/lliria_wms/lliria.map&REQUEST=GetLegendGraphic&LAYER=Edificios&FORMAT=image/gif&version=1.1.1
Otherwise try the URL directly in your browser and see what error message
you get.
Best regards,
Bart
On Tue, 10 Jun 2008 13:49:31 +0200, "Bernardo \(iNCARGiS\)"
<bernardo at incargis.com> wrote:
> I'm just begining with mapbuilde and i have problems in show the legend
> image in my web
> This is the part of my .map file
>     LAYER
>           NAME      EDIFICIOS
>           DATA      LLIRIA
>           STATUS  ON
>           TYPE      POLYGON
>           GROUP    BASE
>           PROJECTION
>             "init=epsg:23030"
>           END
>           DUMP TRUE
>           TOLERANCE 10
>           TEMPLATE "edificios.html"
>           METADATA
>               "wms_srs"                 "EPSG:23030"
>               "wms_name"              "Edificios"
>               "wms_server_version"  "1.1.0"
>               "wms_format"            "image/gif"
>               "wms_legend_graphic" "true"
>           END
> And this is my map context
>   <Layer queryable="1" hidden="0">
>    <Server service="OGC:WMS" version="1.0.0" title="OGC:WMS">
>           <OnlineResource xlink:type="simple"
xlink:href="http://localhost/cgi-bin/mapserv.exe?map=d:/www/lliria_wms/lliria.map"/>
>    </Server>
>    <Name>Edificios</Name>
>    <Title>Edificios</Title>
>    <SRS>EPSG:23030</SRS>
>    <FormatList>
>     <Format current="1">image/gif</Format>
>    </FormatList>
>    <StyleList>
>     <Style current="1">
>      <Name>default</Name>
>      <Title>default</Title>
>      <LegendURL format="image/gif">
xlink:href="http://localhost/cgi-bin/mapserv.exe?map=d:/www/lliria_wms/lliria.map&REQUEST=GetLegendGraphic&LAYER=Edificios&FORMAT=image/gif"/>
>      </LegendURL>
>     </Style>
>    </StyleList>
>   </Layer>
> The legend is defined inside the map file
>           TRANSPARENCY 100
>           CLASSITEM "USO"
>           CLASS
>               NAME "ACERAS"
>               EXPRESSION "ACERA"
>               COLOR               -1 -1 -1
>               OUTLINECOLOR    104 104 104
>           END
>           CLASS
>               NAME "BALSAS"
>               EXPRESSION "BALSA"
>               COLOR               151 219 242
>               OUTLINECOLOR    64 101 235
>           END
>           CLASS
>               NAME "EDIFICIOS"
>               EXPRESSION "EDIF"
>               COLOR               255 234 190
>               OUTLINECOLOR    255 211 127
>           END
> The imgage map is right but the legend no.
> Thanks in advance
