[mapserver-users] WMS Client setup not sending any requests
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Wed Jun 11 04:15:28 EDT 2008
Tough question, as the problem can has many origins, or even multiple
origins...
Having seen your .map, I assume that the main parameters are correct.
Maybe one first pointto check is the scale : the getCapabilities says
for raster100 : <ScaleHint min="40000" max="160000"/>
and you set in your layer section scales from 500 to 20000.
I don't think your initial extent (3037978.75 6622010.94 3767454.98
7790000) falls into that. Can you try with a more adequate extent ?
Also, you are requesting a jpeg image from the wms server to render your
map in png. Try to ask for png as the server allows that.
Hint : to test a mapfile directly, you can use shp2img which will try to
draw the image as defined in the mapfile. use shp2img -o test.png to get
the resulting image into test.png file.
Hope that helps,
Guillaume
GoneWacko a écrit :
> Hello,
> I am currently working on a project where I’m trying to use Mapserver as
> a WMS client, intending to have Mapserver handle the overlaying of data
> for me. The WMS service I’m going to be using one licensed from the
> National Land Survey of Finland.
> This server only supports HTTPS connections and requires Basic
> Authorization to get data from the service. This may prove to be an
> issue for me in the future, but at the moment I’m having (what I suspect
> to be) a different problem.
> When I test my Map file, which to the best of my (currently limited)
> knowledge of Mapserver, should work, I only get entirely white images
> back from the mapserv binary. I’ve not yet figured out how to get
> mapserv to do verbose logging, but the logging it does so far does not
> show me what the issue might be.
> I’ve been trying to get it to work on linux, but then when it didn’t I
> tried it on my local windows machine as well. Both machines display the
> same white image.
> The output of my mapserv –v invocations:
> On Linux:
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=GEOS INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> On Windows:
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS _SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> The map file I’m using can be found at the following location:
> http://www.gonewacko.com/work/finland.map
> For more information about the capabilities of the WMS Server I’m trying
> to connect to, I’ve uploaded the results of a GetCapabilities request
> here: http://gonewacko.com/work/GetCapabilities.xml (Most of the text is
> in Finnish; Which I don’t actually understand myself, but luckily it’s
> not too relevant).
> The URL I’ve been using to test it has usually just been
> http://example.com/cgi-bin/mapserv?map=/path/to/finland.map&mode=map
> <http://example.com/cgi-bin/mapserv?map=/path/to/finland.map&mode=map>.
> My theories are
> - The map has been set up in such a way that mapserv
> finds it’s not within the area I’m requesting, and as such does not
> attempt to render it.
> - The map has just been set up incorrectly (most likely)
> Note that the only files I have are the map file. I do not have any
> shape files or anything of that nature. And apart from the censored
> login information in the URLs, the map file is available in its entirety.
> Also note that I’ve tried replacing the WMS URLs with something that is
> not a https url (i.e. a normal http url), as well as omitting the
> authorization data. It still wouldn’t send a request to the URL.
> Can anyone shed some light on what I’m doing wrong? Thanks in advance.
> Best Regards,
> Stijn Gijsen
> mapserver-users at lists.osgeo.org
