[MAPSERVER-USERS] MapFile2XML conversion - WAS:
mapObjectserialization in C# (variant)
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 11 06:11:12 EDT 2008
Oh no, please do not move to XML as the only alternative, at least not without making a very-easy-to-use XML-Mapfile editor for mortals like me with the same.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Barend Kobben
> Lähetetty: 11. kesäkuuta 2008 10:41
> Vastaanottaja: Bob Basques; mapserver-users at lists.osgeo.org
> Aihe: Re: [MAPSERVER-USERS] MapFile2XML conversion - WAS:
> Hi Bob,
> YES, by all means do move to XML. I think this would be a
> very important step forward (and my first guess is it would
> be not too complicated, but you never know...).
> I do see how some might be attracted to having an DB storage
> too, but I would urge you to always have that as an
> alternative, not as instead-of:
> keep the main configuration mechanism (XML-)file based! In
> many use cases there's no need for a DB and that would mean
> you'd have tho have a DB plus all its hassle, only for the
> configuration part. Also the current file-base config is
> ideal in situations were many people need to work on the one
> MS, such as in our educational setup, where we have many
> students working on their own config files in their private
> dirs, and they don't need to touch the 'main' MS setup on the server.
> Actually, what are your reasons for preferring an SQL
> sdolution over the file based one...?
> Barend Köbben
> International Institute for Geo-Information Sciences and
> Earth Observation (ITC) PO Box 6 7500AA Enschede, The Netherlands
> +31 (0)53 4874253
> On 10-06-08 20:30, "Bob Basques" <Bob.Basques at ci.stpaul.mn.us> wrote:
> > All,
> > We've been pondering some sort of alternative to the
> Mapfiles for a few years
> > now. A preferable approach would be something that could
> be stored in a DB in
> > some fashion for querying/assembly processes. It seems on
> the surface like a
> > DB schema could be developed to handle the MapFile storage aspects.
> > A first step would be in how to best approach moving into
> an XML way of life
> > for the MapFiles. Would it make any sense in the beginning
> to just build a
> > MapFile2XML convertor (I would imagine this would be needed
> before anyone
> > would sign up for XML) and once something like this is a
> state close to
> > production, the innards of MapServer would then be made to
> parse the XML
> > directly?
> > Another approach might be to do something like MapFile2SQL
> first, and then the
> > MapFile2XML. This might save some time and seem like it would make
> > standardization easier, since it would need to be inside of
> the DB fist.
> > Has anyone tried putting together any requirements list
> along these lines at
> > all? Is it going to be something where we just need to
> jump in and build
> > something even if it might be a wrong approach to begin with?
> > This thread just got me thinking is all . . .you know how
> dangerous that can
> > be . . . :c)
> > bobb
> >>>> "Tamas Szekeres" <szekerest at gmail.com> wrote:
> > Hi,
> > MapServer currently doesn`t support any other persitence
> > representation than the mapfiles. There have been some initial plans
> > related to an XML format in this list, but no one had any motivation
> > to implement that.
> > So I think the best what you can do at the moment is to use
> reflection
> > to access the properties along with some other members of
> the objects
> > and serialize the values manually.
> > Best regards,
> > Tamas
> > 2008/6/9 BrainDrain <paulborodaev at gmail.com>:
> >> Is there any 'standart' fast(!) way/method to serialize
> (xml/json/other
> >> markup) mapObj in C#? I need it for using server mapObj as
> JSON on rich
> >> client app running on browser. Look at my method (using
> reflection):
> >> public static ListDictionary PartialSerialize(object
> instance, Stack
> >> callerTypes, Type[] excludeTypes)
> >> ListDictionary result = new ListDictionary();
> >> object val;
> >> callerTypes.Push(instance.GetType());
> >> PropertyInfo[] pis = instance.GetType().GetProperties();
> >> foreach (PropertyInfo pi in pis)
> >> if (pi.PropertyType.IsSerializable &&
> >> !pi.PropertyType.IsArray)
> >> result[pi.Name] = pi.GetValue(instance,
> new object[0]);
> >> else
> >> //preventing useless nesting
> >> if (!callerTypes.Contains(pi.PropertyType) &&
> >> !((IList)excludeTypes).Contains(pi.PropertyType))
> >> val = pi.GetValue(instance, new object[0]);
> >> if (val != null)
> >> result[pi.Name] = PartialSerialize(val,
> >> callerTypes, excludeTypes);
> >> callerTypes.Pop();
> >> return result;
> >> So I can convert mapObj on serever to hashtable
> automatically an then
> >> populate JSON object
> >> (still need to call explicitly getLayer, getClass etc.,
> but this is not a
> >> problem):
> >> layers[i].Properties = Tools.PartialSerialize(layer, new
> Stack(), new
> >> Type[3] { typeof(mapObj), typeof(hashTableObj), typeof(colorObj)});
> >> classes[j].Properties = Tools.PartialSerialize(layerClass,
> new Stack(), new
> >> Type[4] { typeof(layerObj), typeof(labelObj), typeof(hashTableObj),
> >> typeof(colorObj)});
> >> styles[k].Properties = Tools.PartialSerialize(classStyle,
> new Stack(), new
> >> Type[2]{typeof(hashTableObj), typeof(colorObj)});
> >> mapStub.Properties = Tools.PartialSerialize(map, new
> Stack(), new Type[11] {
> >> typeof(labelObj), typeof(hashTableObj), typeof(fontSetObj),
> >> typeof(labelCacheObj), typeof(outputFormatObj[]),
> typeof(queryMapObj),
> >> typeof(referenceMapObj), typeof(scalebarObj), typeof(symbolSetObj),
> >> typeof(colorObj), typeof(legendObj)});
> >> JavaScriptSerializer class object allows to perform
> convertion to client
> >> More often I use script method in my web service that can
> do it behind the
> >> scenes.
> >> How do you do such kind of operation?
> >> View this message in context:
> http://www.nabble.com/mapObject-serialization-in-C--%28variant
> %29-tp17739919p
> >> 17739919.html
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> International Institute for Geo-Information Science and Earth
> Observation (ITC)
> Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is
> intended for the addressee only. If you are not the intended
> recipient, you are hereby notified that any disclosure,
> copying, distribution or action in relation to the content of
> this information is strictly prohibited. If you have received
> this e-mail by mistake, please delete the message and any
> attachment and inform the sender by return e-mail. ITC
> accepts no liability for any error or omission in the message
> content or for damage of any kind that may arise as a result
> of e-mail transmission.
