[mapserver-users] RE: WMS Client setup not sending any requests
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 11 06:57:42 EDT 2008
I took some lines of a working mapfile for cascading WMS. These extents are covering the whole Finland. If you make a request with pure &mode=map map level extents are used as bounding box. By setting also the bounding box in request you will have much better control on what is happening.
I would be nice to hear about what solution you will find for basic authentication. I should be using the same WMS service as you.
-Jukka-
EXTENT 3009960.000 6630040.000 3749960.000 7850040.000
WEB
IMAGEPATH "d:/ms4w/apps/data"
METADATA
"wms_title" "WMS-server"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe <http://localhost/cgi-bin/mapserv.exe> ?"
"wms_srs" "EPSG:2393"
END
END
LAYER
NAME "WMS-orthophotos"
STATUS ON
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http:// <http://map.genimap.com/GenimapWMS/v1/GenimapWMS?cid=mmm&pwd=eaad3e01047aeb4ca8a4a4d53a747e&lang=fi> ....."
UNITS METERS
SIZEUNITS PIXELS
MAXSCALE 12000
TOLERANCEUNITS PIXELS
METADATA
"wms_name" "orthos"
"wms_format" "image/jpeg"
"wms_server_version" "1.1.1"
END
END
