[MAPSERVER-USERS] MapFile2XML conversion
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Wed Jun 11 11:39:30 EDT 2008
John,
You're starting to think about two different applications of XML. I was interested in setting up the XML to reflect the typical MapFile contents and use the XML for the Map generation out of MapServer. KML is a output format option, that would be output by MapServer, (possibly using this new XML MapServer control) to format the KML output.
I would still tend to keep the configurations as file based as well, the DB approach just aloows for much more flexibilty for those hardcore programmers, and the MapFiles, don't input into a DB very easily.
bobb
>>> John Callahan <diodata at udel.edu> wrote:
Is it possible to allow MapServer to use KML, or a variation thereof?
I really don't what would be entailed. For example, KML can store
coordinates for displaying vectors, which would be pointless in our
context. Can KML point to shapefiles or tables for vectors like it can
point to TIFs for rasters? If so, it seems like the infrastructure
(styling, external editing packages, viewers, conversion tools, wide
adoption) is already there to build on. Can we pull pieces from KML to
make it easier for people to adopt without learning a new structure?
+1 on keeping the configuration maps as file based. Databases are great
for many reasons but add an entirely new level of complexity (and points
of failure) for any application.
- John
John Callahan
Geospatial Application Developer
Delaware Geological Survey
University of Delaware
227 Academy St, Newark DE 19716-7501
Tel: (302) 831-3584
Email: john.callahan at udel.edu
http://www.dgs.udel.edu ( http://www.dgs.udel.edu/ )
Barend Kobben wrote:
> Hi Bob,
> YES, by all means do move to XML. I think this would be a very important
> step forward (and my first guess is it would be not too complicated, but you
> never know...).
> I do see how some might be attracted to having an DB storage too, but I
> would urge you to always have that as an alternative, not as instead-of:
> keep the main configuration mechanism (XML-)file based! In many use cases
> there's no need for a DB and that would mean you'd have tho have a DB plus
> all its hassle, only for the configuration part. Also the current file-base
> config is ideal in situations were many people need to work on the one MS,
> such as in our educational setup, where we have many students working on
> their own config files in their private dirs, and they don't need to touch
> the 'main' MS setup on the server.
> Actually, what are your reasons for preferring an SQL sdolution over the
> file based one...?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080611/f38433a6/attachment-0001.html
