[mapserver-users] Show only one POI on the map
Tamas Szekeres szekerest at gmail.com
Sat Jun 14 13:03:19 EDT 2008
Valerio,
If you use mapserver CGI I wonder if the run-time substitution is
applicable for you:
http://mapserver.gis.umn.edu/docs/howto/runsub
Best regards,
Tamas
2008/6/14 valerio vianello <valerio.vianello at yahoo.it>:
> Hi Tamas,
> thanks for the replay,
> I can set the FILTER into the map file but How can I change the FILTER value
> from the template ?
> I need to change the point to show dynamically based on user selection.
> At the moment the only solution that I have found is to put each Poi in a
> different layer using a filter in each layer to choose the Poi. So from the
> template to change the Poi  the user have to change the layer.
> But I hope to find a better solution.
> best regards,
> Valerio
> --- Sab 14/6/08, Tamas Szekeres <szekerest at gmail.com> ha scritto:
> Da: Tamas Szekeres <szekerest at gmail.com>
> Oggetto: Re: [mapserver-users] Show only one POI on the map
> A: valerio.vianello at yahoo.it
> Cc: "mapserver" <mapserver-users at lists.osgeo.org>
> Data: Sabato 14 giugno 2008, 16:24
> Valerio,
> How about setting a FILTER based on the attributes of the layer so as
> to select the single point to be rendered?
> Best regards,
> Tamas
> 2008/6/13 valerio vianello <valerio.vianello at yahoo.it>:
>> Hi,
>> I have a map with some point of interest on top of it, these POIs are
>> divided in three categories. In the map file I used three layers, one for
>> each category and I could decide which kind of POIs shown on the map using
>> the layers variable from the template file. But if I want to show only one
>> POI on the map  what I have to do ?
>> any suggestion ?
>> thanks
>> Valerio
>> ________________________________
>> Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la
>  tua
>> opinione!
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la tua
> opinione!
