[mapserver-users] Show only one POI on the map
Tamas Szekeres
szekerest at gmail.com
Tue Jun 17 06:42:01 EDT 2008
If you use MapScript you probably use the object model (by creating
mapObj at first) and assign values to object properties instead of
using the run-time substitution. You should probably use custom
parameters in the request URLs to communicate between the server and
the client side.
Best regards,
Tamas
2008/6/17 Hans Castorp <hanscastorp76 at yahoo.es>:
> Hi Valerio,
> Do you know how to do the same (runtime variable substitution) using
> Mapscript instead of using the url??
> Thanks in advance.
> ________________________________
> De: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de valerio
> vianello
> Enviado el: martes, 17 de junio de 2008 9:38
> Para: Tamas Szekeres
> CC: mapserver
> Asunto: Re: [mapserver-users] Show only one POI on the map
> Hi Tomas,
> I have found a first solution to my problem.
> I used the cookies to store the variable value end I update the cookie value
> only when the variable change.
> and then in a javascript I update the value of the post field before submit
> the page.
> I'm searching for other solution that don't use cookies...
> thanks
> Valerio
> --- Mar 17/6/08, valerio vianello <valerio.vianello at yahoo.it> ha scritto:
> Da: valerio vianello <valerio.vianello at yahoo.it>
> Oggetto: Re: [mapserver-users] Show only one POI on the map
> A: "Tamas Szekeres" <szekerest at gmail.com>
> Cc: "mapserver" <mapserver-users at lists.osgeo.org>
> Data: Martedì 17 giugno 2008, 08:04
> Hi Tomas,
> My demo is on my local machine for now...but I will show you part of the map
> file and template file.
> this is the layer in which i use the variable the map file is called
> "map1.map"
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER #show single poi
> NAME floor_1_Show_Pois
> DATA POIs
> STATUS OFF
> TYPE POINT
> CLASSITEM "country"
> FILTERITEM 'floor'
> FILTER 'f.1'
> LABELITEM "name"
> TOLERANCE 7
> CLASS
> NAME 'single_poi'
> EXPRESSION '%ccountry%'
> TEMPLATE '../templates/pois.html'
> STYLE
> COLOR 0 0 0
> SYMBOL '../symbols/flag_blue.gif'
> END
> LABEL
> COLOR 0 0 0
> TYPE BITMAP
> SIZE MEDIUM
> ANTIALIAS TRUE
> POSITION LC
> FORCE TRUE
> PARTIALS FALSE
> BUFFER 4
> END # end of label
> END #CLASS
> END # layer Pois with label
> #end ---------------------------------------------
> when I click on same point in the map using mapserver query mode a new page
> is loaded where there is this link to reload the same map file to show only
> one pois:
> <a href="/cgi-bin/mapserv50?map=/var/www/map1.map&layers=floor_1
> floor_1_Show_Pois&ccountry=[country]&imgext=[state]&imgxy=[center]">Show on
> Section </a>
> the page is loaded correct but if I try for example to query to poi I have
> non response or if I zoom in or zoom out into the map the poi disappears.
> I tried to use the field in the template
> <input type="hidden" neme="ccountry" value="[ccountry]">
> but the value of [ccountry is replaced only the first time with the correct
> value then its value become the string "[ccountry]"...
> any suggestions ?
> best regards
> Valerio
> --- Lun 16/6/08, Tamas Szekeres <szekerest at gmail.com> ha scritto:
> Da: Tamas Szekeres <szekerest at gmail.com>
> A: valerio.vianello at yahoo.it
> Data: Lunedì 16 giugno 2008, 20:03
> Valerio,
> I don`t think if anything is preserved across the subsequent requests
> in the cgi mapserver so you might have to apply the substitution on
> each request.
> However I`m not sure I could catch the problem exactly, do you have
> mapfile/URL examples?
> Best regards,
> Tamas
> 2008/6/16 valerio vianello <valerio.vianello at yahoo.it>:
>> Hi Tamas,
>> I have a bit issue
>> Do you know how lock the variable value until the next changing ?
>> Now I am able to show only one poi in the map but if I try to query it I
>> have no results as response. I have done a lot of test and I think the
>> problem is on variable value. after the page is loaded the value of
>> parameter
>> (EXPRESSION '%ccountry%' ) in the map file lose its past value
> and so the
>> mapserver cgi haven't reference to it anymore.
>> any suggestion ?
>> Best regards
>> Valerio.
>> Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la tua
>> opinione!
> opinione!
> opinione!
> No virus found in this incoming message.
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 270.3.0/1505 - Release Date: 16/06/2008
> 7:20
> Enviado desde Correo Yahoo!
> La bandeja de entrada más inteligente.
